Mileage Issues
Old Jul 6, 2010 | 10:00 AM
Stoshwi's Avatar
Stoshwi
6th Gear
Default Mileage Issues
Can some one help me please. I have a 01 carbed 88b. I was getting 40 miles to the gallon before I broke the choke cable and replaced it with a Mikuni cable, because info from the mikuni web site. I have free play in the cable, what would be causing me not to get the previous milage fiqures? The jet is the same, and I replaced the plastic nut to holds the cable.
Old Jul 6, 2010 | 10:17 AM
Gman in NC's Avatar
Gman in NC
If your milage went to pot and you didn't change anything else you are probably not getting the choke opened all the way. That's about the only think it could be.
Old Jul 6, 2010 | 10:20 AM
Stoshwi's Avatar
Stoshwi
6th Gear
Gman how do I check that? I have slack in the choke cable, does that mean the spring is not pushing the plunger all the way down?
Old Jul 6, 2010 | 01:03 PM
Gman in NC's Avatar
Gman in NC
Not sure. I haven't dealt with a carb for awhile. Take off the air cleaner and watch the butterfly work. It should be fully open when the choke button is pushed in. I think the slack in the cable is probably the problem.
Old Jul 6, 2010 | 09:45 PM
snip0721's Avatar
snip0721
if your running a cv style carb, go get the correct cable from your hd dealer. it's actually not a choke, but an enricher. same effect...more fuel on start-up. an incorrect cable WILL NOT allow the enricher piston to fully close. your running on the rich side all the time, thus the poor mileage. fouled plugs soon to follow. usually the rear one first, steve
Slick02
Sep 20, 2021 09:36 AM
BobFLHT2002
Carburetor Related
Jun 7, 2018 08:03 AM
tootal
Carburetor Related
Apr 30, 2016 11:41 AM
Stoshwi
Exhaust System Topics
Jul 26, 2010 08:10 PM
tommylee44
Apr 7, 2008 03:34 PM
