Rear brake rotor getting hot
Have you rebuilt the master cylinder?
Are you sure the caliper is riding in the correct position relative to the rotor?
There are no springs to retract the caliper pistons. They use a square cut seal on the piston, that pulls it back, just a very slight amount, when hydraulic pressure is released. This movement is not visible to the human eye. Most experts I've talked to, believe that even with the retracting motion of the square cut seal, the pads may still make very slight contact with the rotors....
There can be problems when the brake pistons stick and or there is an issue with the square cut rotor seals....
I copied this explanation of how the piston/square cut seal works from an article on Auto Repair by Jim Miller. Don't know the guy, just googled the issue to get an explanation, more eloquent than I could write...
"A round, square cut, “O” ring seal is contained in a groove cut into the caliper bore and provides a seal for the caliper piston. A dust seal is placed around the lip of the caliper piston at the brake pad contact area and is secured in a groove on the outside of the caliper bore. A hydraulic seal is maintained through contact of the caliper piston surface with the caliper seal. The caliper seal also provides two other functions in the disc brake caliper. It acts as a brake return spring to maintain correct clearance between the brake pad and the rotor. The caliper seal is able to do this because of its placement in the groove cut in the caliper bore. The seal groove is cut slightly wider than the caliper seal. When the automotive brakes are applied, the piston slides forward in the bore, moving the caliper seal against the edge of the seal groove. This causes the seal to distort in the same direction as the movement of the piston. When the brakes are released, pressure is removed from the piston and the distortion of the caliper piston seal causes it to pull the piston back slightly and create a small amount of clearance between the brake pads and the rotor."
Hedgehawg71- In your particular case, it sounds like you've properly cleaned the caliper, piston bore, and pistons..... I would suggest you double check that you've put the seals in the proper place, and that they fit properly.... get a service manual if needed to check your reassembly....
Good luck with the repair....
