2000 Fat Boy rear tire
Old Jul 11, 2010 | 05:26 AM
roadtech's Avatar
roadtech
Stage II
Default 2000 Fat Boy rear tire
I will be replacing both tires on my fat boy, but would like to install a fatty on the back. What is the biggest tire the rear fender will take?
Old Jul 11, 2010 | 06:14 AM
Kojax's Avatar
Kojax
Unhappy
rear tire 200
Old Jul 11, 2010 | 08:34 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
160 is the widest you can put without any mods sir.
Drew
Old Jul 11, 2010 | 08:40 AM
tsm1550's Avatar
tsm1550
3rd Gear
roadtech you can but a up to a 200 on but you will need a wider wheel. i put a 200 on mine without any mods. after a 200 you will need to change out the swingarm
Old Jul 11, 2010 | 08:42 AM
tsm1550's Avatar
tsm1550
3rd Gear
dr.v-twin you need to recheck your info
Old Jul 11, 2010 | 08:47 AM
tsm1550's Avatar
tsm1550
3rd Gear
roadtech ur need to turn ur frender bolts inside out with acron bolts on the outside . this will keep the tires from rubbing
Old Jul 11, 2010 | 08:53 AM
tsm1550's Avatar
tsm1550
3rd Gear
u will need a nine inch fender with external struts. but no mods to any drive train
Old Jul 11, 2010 | 08:56 AM
Nick-O's Avatar
Nick-O
Putting a 200 on a 2000 fatboy original fender???....can't do it man. The fender isn't 8" wide....YOU need to check your info. Drew is on the money.
Old Jul 11, 2010 | 09:55 AM
KumaRide's Avatar
KumaRide
.... i put a 200 on mine without any mods. after a 200 you will need to change out the swingarm
Any pics of your 200 tire without any mods? Or, are you sayin that a fender, struts, wheel... are not considered mods?
Roadtech, the Dr's right. 160 on a 2000 FB. A 160 tire does fit better on a rim wider then 3" - I believe that is what you have? Check the tires recommended rim sizes before proceeding.
Old Jul 12, 2010 | 07:32 AM
Nickrc3's Avatar
Nickrc3
This I want to see...
