'08 Deluxe cable change
Old Jul 14, 2010 | 09:04 AM
Jerf01's Avatar
Jerf01
Default '08 Deluxe cable change
Just trying to drain the Trans fluid, need to be sure which plug to remove for draining. Is it the plug between the shockes?
Old Jul 14, 2010 | 12:00 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
yes sir it is.
Old Jul 14, 2010 | 01:24 PM
Rockyriver's Avatar
Rockyriver
Just as a word of caution ( I know you asked about the tranny). If you ever change the engine oil never remove the plug in the bottom of the engine. The drain plug for the engine oil is at the swingarm in the rear and underneath. Removing the plug at the bottom of the engine can cause engine damage. You may already know this, but I thought I would just mention it. And yes the tranny plug is between the shocks on a softail.
The primary plug (for clutch oil and primary chain oil) is on the bottom of the primary cover on the left side.
Old Jul 14, 2010 | 01:38 PM
jimmers1817's Avatar
jimmers1817
Oh boy, jumping right into the hard stuff first. Rest of the project should go easy.
tom lipke
Nov 28, 2022 05:28 PM
bigtexasrob
Oil Archive (no new posts)
19
Mar 27, 2021 03:39 PM
Ring
Apr 22, 2010 07:27 PM
roqueweiler
Apr 20, 2009 08:02 PM
jpjurrens
Nov 29, 2008 04:57 PM
