Primary Noise- Need Advice
The bike is a stock '07 FXSTC with just over 10K miles. No previous mechanical issues, no leaks or other issues evident.
Symptom (Hard to tell if noise is present when riding, but am able to hear it when stationary as follows): Start the bike in neutral, clutch out, no noise. Pull clutch in, no noise. Put in gear, clutch in, no noise. Let clutch out slightly while in gear to put some tension on the drive train, no noise. Pull clutch all the way back in and shift back to neutral, no noise. Let clutch back out while in neutral, lots of noise. Pull clutch in and out the noise will fade in and out as the primary chain rotates/stops.
Not sure how to describe the noise other than like it always sounded only 100x louder. Not a grinding or high pitched howl. Almost a loud "swirling" sound.
I did stop by the dealer. The service manager thought it could be a problem with the chain tension block (From the sound, I tend to agree). He had a seasoned mechanic listen. This guy stated last time he heard a sound like that, it was a bad bearing. He was pointing near the back of the primary, near the tranny. (Don't recall exactly which bearing, said something like idle, or float, or take-up, or something like that.) Both agreed that it was not a normal sound.
Here's where I need the help: The chain block issue would appear pretty straight forward. The bearing issue I need some further information on as to which one he would be talking about. Also, would any special tools be required to fix either. Would I need to go deeper than the outer primary cover?
I have worked on quite a few vehicles when I was younger, don't really enjoy it like some people. I either have or have access to most standard tools, including bike jack, torque wrenches, etc.
I do not want to spend unknown, big dollars to have the dealer fix (not under warranty), nor do I want to pull off the primary cover looking for something that is not easily identifiable or that may require special tools.
Any insight to share?
-stef
ride safe
"xmns" = transmission?
Are the two bearings easily accessible without special tools needed to replace? Need to go any deeper than parts accessible after removing the outer primary cover?
I'm confident I'll be OK going in with the manual for reference, just like to know before tearing things apart how involved/complex it might be. (I tend to over plan and hate surprises.)
Any other constructive thoughts/ ideas would be appreciated.
-stef
-stef
Update:
Currently have the primary cover off. Chain tension mechanism and everything else looks good visually. Not sure if there is a way to check these bearings short of pulling everything apart, perhaps replacing them just in case.
Ideas anyone?
-stef
