07 RG noise--bad
Old Aug 10, 2008 | 01:02 PM
mccpdx's Avatar
mccpdx
Angry 07 RG noise--bad
noise from primary side after running for 5 minutes--can make it happen in gear only and with clutch just being released but not moving the bike--increases w/speed of motor--otherwise no noise while riding--verified compensator bolt torque--tensioner good and clutch adj is o.k.--with ear on primary cover it is worse by clutch assy--also warranty is up today--notified dealer but service is not open today
Old Aug 10, 2008 | 02:55 PM
Dalton's Avatar
Dalton
You haven't described the type of noise but there is very little inside the primary to go bad. Could be an inner Primary bearing or clutch basket bearing.
What type of noises are you hearing?
Old Aug 10, 2008 | 04:42 PM
mccpdx's Avatar
mccpdx
it is a loud knocking noise--noiser than a chain hitting something--no signs of anything hitting--oil and magnet are clean--if you release clutch and start moving it is quiet--only in that small area of clutch movement--it's as if some clearance is being taken up--definitaly at rear of primary cover--bike has 10,000 miles
Old Aug 11, 2008 | 08:07 AM
CDN. RG's Avatar
CDN. RG
I get a clanking noise from my primary on my 07 road glide when taking off sometimes ,but everything seems nice and smooth once moving,it started at about 10000 miles,it doesn't do it all the time and is usually more prevalent when warmed up,I still have 1 year left on my warranty so I am going to keep an eye (ear) on it and see if it gets any worse,but would be intrested in hearing what the dealer has to say about yours .
Old Aug 11, 2008 | 12:18 PM
iclick's Avatar
iclick
I get a clank occasionally when disengaging the clutch, mainly when decelerating, as if some slack is being taken up. Haven't thought much about it, as it isn't loud, and chain tension appears normal. No noises at any other time. Bike has about 21k.
BigDogHawg
Oct 16, 2016 09:26 AM
GPHDXLC
Aug 23, 2012 12:58 PM
krom nutz
Dec 15, 2010 05:39 AM
stef
Jul 17, 2010 03:27 PM
Road King Kid
May 3, 2007 11:00 PM
