Clutch adjustment
Old Aug 4, 2010 | 09:11 AM
a4x4high's Avatar
a4x4high
Default Clutch adjustment
I have an 06 heritage classic and my service manual is packed away from a recent move can someone refresh my memory on adjusting the clutch not the cable but the clutch itself ,I think its loosen lock nut turn adjuster in till it bottoms on pushrod them back off 1/4 turn but not sure.
Old Aug 4, 2010 | 09:23 AM
dennyo's Avatar
dennyo
I back mine off a 1/2 a Turn , I think the book says 1/2 to 1 turn back
Old Aug 4, 2010 | 09:39 AM
Arlensmess's Avatar
Arlensmess
5th Gear
You need to shorten the clutch cable first all the way. Then go under the derby, loosen the lock nut, take your allen and screw the adjuster in until contact and go a little further. Now rotate the allen back and forts to squeeze any fluid out from between the rods. Loosen until it releases and tighten until you feel it contact... come out 3/4 turn. Hold adjuster and lock the nut back down.
Old Aug 4, 2010 | 09:48 AM
a4x4high's Avatar
a4x4high
I know about the clutch cable I just needed the spec for adjusting clutch itself
89FLHTC
EVO
11
May 3, 2016 07:34 PM
P51Driver
May 21, 2013 07:15 PM
keatingiv
Jun 5, 2012 06:04 PM
JE1957
General Topics/Tech Tips
May 28, 2010 07:06 AM
rjmac53
Mar 24, 2008 07:21 AM
