2004 FXST - How much Fork Oil?
Old Aug 11, 2010 | 07:16 AM
Mario77746's Avatar
Mario77746
Default 2004 FXST - How much Fork Oil?
I put in some progressive springs and 2" shorter tubes. I called the stealer to see how much for oil. The first one said maybe 9 oz. I ask if they actually knew instead of getting a maybe. They put me on hold then came back a min later and said 9. I called a second one and they said 11 oz. Does anyone know what the manual says for any 2000 and up FXST?
Thanks.
Old Aug 11, 2010 | 07:34 AM
Mario77746's Avatar
Mario77746
I guess I spoke too soon. The search function did not bring the up but Google did. Or maybe I just didn't go back far enough......This was posted by Skycrane.
"Dry fork requires .5 to 1.0oz more than the wet amount due to residual oil left clinging inside the fork." Use 20 weight for average conditions. For extreme conditions use 10 weight or 30 weight accordingly."
-WET: Means you just drained the oil out of the plug and want to refill it.
-DRY: Means you dissassembled the forks and cleaned them dry inside/out.
WET.....DRY...(oz)............MODEL/YEAR.........................................
5.5 ..... 6.5 ...... Sportster thru 1972
5.0 ..... 6.0 ..... Sportster 1972-83
5.4 ..... 6.5 ..... Sportster 1984-87
9.0 ..... 10.2 ..... Sportster 1988-2003
10.5 .... 11.6 ..... Sportster 2004-08
9.0 ..... 10.2 ..... XL 883 Hugger thru 1991
10.7 ..... 12.1 ..... XL Hugger 1992-99
6.5 ..... 7.0 ..... FL/FLH 1948-E77
7.75 ..... 8.5 ..... FL/FLH L1977-84
7.75 ...... 8.5 ..... FLT 1980-97
8.7 ..... 9.7 ..... FLT 1998-2001
10.1 ..... 11.1 ...... FLHR 2002-09
5.5 ..... 6.5 ..... FX/FXE 1972
5.0 ..... 6.0 ..... FX/FXE 1973-83
6.0 ..... 7.0 ..... FXR/FXRS 1985-86
9.0 ..... 10.2 ..... FXR/FXRS 1991-94
9.2 ..... 10.2 ..... Dyna/Low Rider 1991-2005
10.2 ..... 11.2 ..... Dyna Wide Glide 1991-2005
9.0 ..... 10.2 ..... FXWG/FXST 1980-84
10.2 ..... 11.2 ..... FXWG/FXST 1985-2006
11.5 ..... 12.5 ..... FLST 1986-2006
12.4 ..... 13.4 ..... FLST 2007-09
11.5 ..... 12.5 ..... FXST 2007-09
10.5 ..... 11.6 ..... FXSTD 2007
oct1949
Mar 27, 2017 10:49 AM
nwpaironhead
Ironhead
Oct 25, 2009 09:49 PM
aquaskiman
Aug 23, 2006 10:07 PM
allkay
Dec 9, 2004 03:47 PM
