Front brake problem
Old Aug 13, 2010 | 12:02 AM
RedBen's Avatar
RedBen
I haven't had a chance to put it on the lift. Maybe tomorrow. It's possible the MC is over filled. I'll check that next if it's still an issue.
Old Aug 13, 2010 | 09:00 AM
Nickrc3's Avatar
Nickrc3
Kind of hard to change the brake cable without changing the fluid unless I put the old stuff back in.
Actually, there may be old, residual fluid within the master cylinder that if not flushed, will be introduced into the system.
I recommend a Mity-Vac ($45.00) because you can observe all old fluid being deposited into the external reservoir as new fluid is pulled through the system. No second bleeding is ever required. Best tool recently purchased!
Twilli6291
Mar 13, 2017 08:51 AM
LA_Dog
Jul 5, 2016 12:16 PM
langwilliams
EVO
May 7, 2016 06:56 AM
red deuce
Jan 7, 2011 09:31 PM
ultraman00
Jul 23, 2008 04:29 AM
