Rocker build finished (18 months later!)
Here she is...
There is a full set of pics here: Photo Album
2009 FXCWC Rocker C - Completed Mods
Custom Paint - http://www.pairadicepaint.com/
- Paint - Classic Flame with Realfire, blown in HD logo, Willie G skull
- Welded/shaved rear fender license plate holes
- Welded front fender struts (removed rivets), shaved
- HD Screamin Eagle CNC Ported "MVA" Heads
- HD Screamin Eagle High Compression Pistons
- HD 103" Big bore kit
- S&S 570 Gear Drive Cams
- HD Screamin' Eagle Heavy Breather Air Cleaner
- Vance & Hines Big Radius 2-into-2 Exhaust (part #26043)
- Power Commander V Fuel Management
Danny Gray Solo Rocker seat with gel insert and flame stitching
2" tank lift (www.chopperstyle.net model # ST/TR2 ordered from J&P)
Heartland License plate relocate - Horizontal footpeg mount and LED light
Flush Front Axle (eBay - mikecorrell2000@yahoo.com)
Chrome
- 62552-09 HD Chrome oil tank
- 48663-08 HD Chrome Swingarm
- 25441-04A HD Willie G. Derby cover
- 32975-04A HD Willie G. Timing cover
- 62811-08 HD Flush mount fuel gauge and cap
- 74597-01 HD Chrome voltage regulator cover
- 60345-08 HD Chrome lower belt / debris guard
- 44345-09 HD Softail Swingarm Axle Cover
- 71985-08 HD Console Insert - Raised Skull
- 69973-08 HD Visor-style headlight trim ring
- 92059-07 HD Front signal mirrors (removed stock front turn signals, added 2-amp load equalizer)
- 48212-08 HD Contoured Frame Inserts - Chrome
- 56391-04 HD Street Slammer Bars
- Novello NIL-618 - 1.5" riser extension for 1.25" bars (J&P, pn 500-961)
- 56807-05A HD Throttle/Idle Cable Diamondback
- 38851-09 HD Clutch Cable Diamondback
- 41842-06 HD Banjo Bolt Kit, Chrome
- DS3542 Chromite II 42" brake line
- Chrome Clutch Cable Clamp (Dennis Kirk, pn 197281)
- 45355-08 HD Clutch and Master Cylinder Kit, Chrome
- 45075-08 HD Hand Lever Kit, Chrome
- 70222-96B HD Switch Housing, Chrome
- 71804-03 HD Chrome Switch Cap Kit
- 56263-96A HD Chrome and Rubber Horizontal Hand Grips
- 50130-95A HD Chrome and Rubber Custom Footpeg
- 42476-95 HD Chrome And Rubber FX Brake Pedal Pad
- 34608-95 HD Chrome and Rubber Shifter Peg
- 43300001 HD Chrome 5 Spoke Rocker wheel - Front
- 40900001 HD Chrome 5 Spoke Rocker wheel - Rear
- 41522-08 HD Chrome Front Wheel Spacer Kit
- 41378-08 HD Chrome Rear Wheel Spacer Kit
- 41452-08A HD Wheel Installation Kit - Front
- 41456-08A HD Wheel Installation Kit - Rear
- 40126-07 HD Thunderstar Chrome Billet Sprocket
- 43245-07 HD Chrome Socket Head Cap Screw Hardware Kit for Rear Belt Sprocket
- 44360-00 HD Chrome Floating Brake Rotor - Front
- 44359-00 HD Chrome Floating Brake Rotor - Rear
- 46646-05 HD Chrome Brake Disc Hardware Kit (Front)
- 46647-05 HD Chrome Brake Disc Hardware Kit (Rear)
- 44395-08 HD Chrome Front Caliper Kit
- 42047-08 HD Chrome Rear Caliper Kit
- Lyndall Z Pads
- 60815-08 HD Chrome Inner Primary Cover
- 60607-08 HD Chrome Hardware Kit - Primary Cover
- 60547-06 HD Primary Cover Gasket
- 27444-00Y HD Primary Cover O-Ring
- 34856-06A HD Chrome Hardware Kit - Transmission
- 94058-03 HD Chrome Hardware Kit - Cam Cover
- 94059-03 HD Chrome Hardware Kit - Rocker Box Cover
- 94068-03 HD Chrome Hardware Kit - Lifter/Tappet Block
Hotwire - I didn't have any parts chromed myself. I attempted to have my wheels/rotors/pulley chromed by a semi-reputable chromer, but the quality was no where near the Harley chrome so I paid the restocking and went with the Harley chrome. Anyway, all those part numbers (like for the swingarm and oil bag) are for the chrome versions fro Harley.
