Injector code help?
Old Aug 24, 2010 | 03:28 PM
hutch1970's Avatar
hutch1970
Default Injector code help?
04' Softail standard efi. My codes have been showing front and rear cylinders not firing- EFI (P1353,P1356). The check engine light first started coming on after a tune about 11,000mi's ago. The check engine code first started coming on when accelerating, then began to just stay on. My bike runs w/ no apparent problems.
Possible bad tune or maybe the injectors are becoming clogged? I did take a road trip around the southern US tallying about 6000mi"s. Bad gas?
I have tried to clear the codes, but they still come back. I also had my pipes off to polish the blues off and to check my tensioner shoes. Fired the bike briefly w/ the pipes off to make sure oil was pumping back around. While firing, the bike appeared to be firing intermittely.
Any ideas? Has anybody else had this problem w/ the solution?
Thanks for your replies in advance.
Old Aug 24, 2010 | 03:41 PM
nomaster's Avatar
nomaster
ive heard of aftermarket plug wires doing that before on this site most people went back to harley or screamin eagle wires if im not mistaken
Old Aug 24, 2010 | 03:49 PM
hutch1970's Avatar
hutch1970
I do have aftermarket plug wires, will check their spark and reply back. Thanks for the idea.
Old Aug 24, 2010 | 04:03 PM
nomaster's Avatar
nomaster
i run screamin eagle on my train with factory plugs never had a single problem
Old Aug 24, 2010 | 06:44 PM
KumaRide's Avatar
KumaRide
Mine would throw codes even after clearing them - bike ran great. Got some electrical contact cleaner, took every plug apart I could find, sprayed with cleaner, and reseated connections - no more codes.
Old Aug 25, 2010 | 03:48 AM
hutch1970's Avatar
hutch1970
Put some Lucas gas/injector cleaner in and the check engine light quit showing constantly. Havn't cleared the codes and re-checked yet- gotta get some sleep.
KumaRide- Thanks, will check and clean connections. I do ride in the rain.
lonelyrider1966
Sep 18, 2013 07:45 PM
philb252
Sep 10, 2013 09:26 AM
HarleyGuy426
Jul 2, 2013 04:33 PM
docsg
Apr 4, 2013 04:21 PM
AZCHOKESTER
Feb 9, 2008 11:15 AM
