rejet question
Old Aug 25, 2010 | 08:09 PM
kirkw101's Avatar
kirkw101
it's all good. It was very early this morning when I asked the question. Before coffee.
so, 70mph in 3rd gear! damn!
Old Aug 25, 2010 | 08:20 PM
Quadancer's Avatar
Quadancer
Note: I edited that with a better method, still kinda brutal.
Old Aug 26, 2010 | 12:08 PM
tk353's Avatar
tk353
get a kit and it is easy.
http://www.harley-performance.com/stage-1-carb-kit.html
Old Aug 26, 2010 | 01:49 PM
Jim Kraft's Avatar
Jim Kraft
On my 99 EVO, I went from a 42 to a 45 pilot jet, and a 170 to 180 main jet. A little over two turns out on the idle mixture screw. That is with drag pipes and a K&N air cleaner. I was able to drop the bowl off the bottom of the carb without removing anything except the air cleaner and mounting plate along with the vent tubes that go to the rocker boxes. Just don't loose the jet needle guide when you drop out the main jet. Mine stayed in when I dropped out my main jet, but I think it is just loose in there. I do not have a crossover pipe on mine which I think made it easier.
Old Aug 26, 2010 | 01:53 PM
98fat's Avatar
98fat
When I ran a CV on my EVO I was running a 46 pilot and a 185 main. You can do it, its not hard. I suggest you replace any soft screws with stainless hex. Just don't get too tight.
Old Aug 26, 2010 | 05:21 PM
Quadancer's Avatar
Quadancer
I probably have just one removal left on my phillips. You happen to know the thread count? I would go with allens, not hex, for the bowl.
Old Aug 31, 2010 | 03:51 PM
flh80's Avatar
flh80
I changed mine and my wifes A/C and exhaust's. Didn't have to re-jet, they run fine and plugs buring good, dealer says the carb's were set up on the fat side from the factory any way cause they know most people change someting right away.
Don the duck
Sep 7, 2017 07:57 AM
glennt7
Aug 13, 2010 10:15 PM
nickdv9
Jul 11, 2007 10:01 PM
CWebb3
Sep 1, 2006 01:53 PM
nfe
Exhaust System Topics
Aug 16, 2005 05:04 PM
