rejet question
Old Aug 25, 2010 | 06:07 AM
kirkw101's Avatar
kirkw101
Default rejet question
So I want to finish my stage 1 upgrades. Namely AC upgrade. I understand that I will need to re-jet my carb but how ard is it to do and can y'all give me some pointers on what to look out for.
Any special tools needed? what size jet(s) should I try?
thanks
kirk
Old Aug 25, 2010 | 06:17 AM
kirkw101's Avatar
kirkw101
will I have to remove the carb or can this be done just by removing the AC cover and filter?
kirk
Quadancer's Avatar
Quadancer
Since you didn't even tell us what BIKE you're riding, you obviously don't know enough to tackle your own work or have a manual. Do you know where the carburetter IS?
Old Aug 25, 2010 | 06:54 AM
Notgrownup's Avatar
Notgrownup
I did this with basic tools on my 05 XL883C... went from a .45 to a .47 jet...pretty simple...i took the carb off. Oh, yeah like Quad said....nice to know what bike you have because you might get more specific help...
Old Aug 25, 2010 | 09:45 AM
Nautilus's Avatar
Nautilus
a bit on the rough side there quad... but he has a point somewhere there...
we cannot help u if u don't post what bike is it... and we're assuming it's carbed and not a brand new efi type right?
just give us the model and year and additional info like what exhaust are u running and we should help a bit more...
plus get a manual ASAP
Old Aug 25, 2010 | 10:19 AM
klf33's Avatar
klf33
FIX MY HOG DVD .. is your best bet + CLymer + Service book for your bike year.. and (like myself) , do it in the winter time because you will mess up a lot and you will need to redo it a few times.. (just the basics of getting the carb out, taking it to pieces, putting it back together and installing it back in again).
The forum here is helpful, have a digital camera ready , take your time and you will be OK
Then in the summer you start riding and testing.
Good luck.
Old Aug 25, 2010 | 11:21 AM
FastHoss's Avatar
FastHoss
Did my 05 the easy way.Drilled a hole through the cover of the a/f mix backed it off 3 turns took the cover off and put the 1988 sporty needle in.Man what a difference.Didn't change jets,nothing like that.Bike runs great.Went from 53 mpg to 42 mpg the only time it spits now is when I forget to turn on the fuel.
Old Aug 25, 2010 | 11:29 AM
mike06train's Avatar
mike06train
Not a hard job. BUY THE SERVICE MANUAL!!!! Shoot us the bike info so people can get more spicific. If it's a newer bike with FI it's going to go another direction.
Old Aug 25, 2010 | 07:32 PM
kirkw101's Avatar
kirkw101
the carb is the big thing I put the gas in right?
Manual? isn't he an undocumented worker?
05 fatboy, V&H staggered Short Shots.
hate to pay for some other idiot to do work this idiot can do.
I have the manual, and can read too, yet I still find actual people who have done the job can teach me more practical ways to do it.
thx
kirk
Old Aug 25, 2010 | 08:03 PM
Quadancer's Avatar
Quadancer
Now we're talking. The sporty needle is about the best mod you can do to your CV carb as suggested.
The main jets are sufficient to handle stage 1 - a test (a bit on the nasty side) is:
To test the main jetting, you must be in fourth or fifth gear and running fairly high RPM (4000+) then open the throttle all the way to the throttle stop, noting the feel of the bike. Immediately let off the throttle about 1/8 turn and note the feel of the bike. If it seems to accelerate some when you let off the 1/8, your main jet is too lean. If it hesitates or the top speed is poor (i.e. less than 80 MPH) you are too rich. Adjust your main jetting accordingly by increasing or decreasing the jet size by 5.
Pilot jets: You probably have a 45 or 46 in there? You'll want to go up a size at a time until you can get the idle screw to work with just a few turns out. I even had to go to a 50 for mine.
Apologies for the bad mood earlier.
