Heritage battery won't charge
Old Aug 30, 2010 | 06:59 AM
pessemist's Avatar
pessemist
Stage I
Default Heritage battery won't charge
Hey guys-
I have a 1994 Heritage softail and the battery does not charge.
I have done the following:
1) Replaced battery
2) Replaced regulator
I get 12.6 volts at the battery which drops to 12.48 when the engine is running.
I get 30-45 volts ac at the stator pins
The 30amp fuse block is testing good.
Any ideas why the battery is not getting voltage? The Stator seems to be putting out the right AC current?
doug
Old Aug 30, 2010 | 08:43 AM
jeff7373's Avatar
jeff7373
Stage II
Originally Posted by pessemist
Hey guys-
1) Replaced battery
doug
I just had the same problem on my 94 fatboy. do an ohm test from the motor to the leads on the stator (engine off and unplug the stator), you should have nothing! if you do its a bad stator...this is common for these bikes and 90% of the time it turns out to be the stator is burnt or shorted to the case and somtimes you still get ac voltage but not enough to run the charging system.
bucksy99
Jul 5, 2016 06:42 PM
Pinetop
EVO
Apr 12, 2014 08:50 AM
NickSchoff
EVO
11
Jul 5, 2013 11:49 AM
Bubba97
Jun 20, 2012 01:20 PM
hucks 08
May 26, 2010 07:23 PM
