dont need a pic just measure the damn shock ...that way you will know if your dropped 2 inch cuz i think your not....mine looked killer with 2 inch drop...you got somthing weird going on...the pic i posted above is a normal 17 inch wheel dropped 2 inch and looks fine no dirt bike action...and the preload is set stiff or middle
yea mine wur a little longer..mine wur 3 7/8 not much but everybit of threads(not inches) drops alot when it comes to the fender/tire ratio..my nuts wur on the end of the threads too with red lock tite .if your getting a longer set "made" make sure its grade 8 dont want them to snap that would hurt...
Well, here's a few pix of the new set-up with the Heartland EZ200 kit.
As you can see, the rear needs some dropping.
The lights on the struts are single-intensity Kuryakyn Mini-Bullets which are used as directionals. The one on the right side of the frame is a running light.
The license plate holder is the one I got dicked on by DemonsCycle.com. My local wrencher machined a new bracket for me and made it work. Thanks Joe! It's a running/brake light. When my wife gets a new job, I will be adding a flexible LED strip under the lip of the fender as a running/brake light.
So... I still have work to do- black powdercoated pullback bars, painting of tins, lowering the rear, LED strip, new tires, brakes... ho boy.
JY i can tell you right now by looking at the swingarm it don't look like you got 2 inches on your drop... take a picture from the side close up of where the swingarm pivot and the oil can... and then maybe we can match it up to how close other peeps swingarm comes to the to the oil can. Now worries man you'll get it worked out before long. You know maybe it's because the light color and makes it look even higher then it is?
finally i was gettin worried you didnt own a bike LOL
dude yer stylin man rattlecan some paint on there until
mamma geta a job then start a ponze scheme for your
air ride
good weekend
