'02 fxsti won't start after security system use
Old 09-04-2010, 10:03 PM
fkhull's Avatar
fkhull
fkhull is offline
Stage III
Default '02 fxsti won't start after security system use
I've had the security system on for a couple weeks and my bike just cranks over but won't start. This is the 2nd time this has happened, the 1st time it eventually started, but today, it just ran down the battery. I realize there is a constant drain on the battery by the security system and hope the battery was not providing enough juice to fire properly. Anyone else experience the same thing?
Old 09-05-2010, 09:22 AM
handyhoward's Avatar
handyhoward
handyhoward is offline
Yep... put a trickle charger on the bike if you leave it sitting for more than a few days... extends battery life.
Old 09-05-2010, 07:22 PM
fkhull's Avatar
fkhull
fkhull is offline
Stage III
I've had the trickle charger on it overnight and today and still no start.
Old 09-05-2010, 07:29 PM
wildman67's Avatar
wildman67
wildman67 is offline
how old is the battery?
Old 09-06-2010, 06:19 AM
handyhoward
If the trickle charger shows the battery to be fully charged and your bike is not starting... then the next check is for a spark at each of the plugs. Rather than me writing what has been written a thousand times... google or bing "how to check for a spark at the plug" and follow directions. I am assuming that you checked to make sure your gas tank has gas in it and your petcock is in the run position.......
Old 09-07-2010, 11:52 AM
fkhull's Avatar
fkhull
fkhull is offline
Stage III
Drain on the battery and flooding were the 2 culprits, finally started late last night.
Old 09-07-2010, 02:11 PM
DR. V-TWIN's Avatar
DR. V-TWIN
DR. V-TWIN is offline
Former Sponsor
I have a 2002 softail with an alarm and the smart siren on it. I have never had an issue with it starting as a result of either. You might want to make sure your battery cables are tight, the battery ground is tight, relays are connected firmly, etc.
Drew
Potato_Potato
05-23-2014 10:38 PM
ktrick01
10-29-2013 06:36 PM
flynavy
01-30-2013 05:56 PM
studiopeg
05-06-2011 10:08 AM
lazybee
06-26-2007 06:21 PM
Quick Reply: '02 fxsti won't start after security system use
