TORQUE specs for 2007 nighttrain
Old Sep 10, 2010 | 04:10 AM
20Sporty06's Avatar
20Sporty06
Default TORQUE specs for 2007 nighttrain
Hello People my buddy is replacing a belt on his 07 nighttrain. need torque specs for following items please:
1. Swing Arm Axle
2. The Axle itself
3. Inner and OUter Primary
4. Clutch Hub
5. Front Gear Primary Chain
Would greatly appreciate it. thank you guys!!!!
Old Sep 10, 2010 | 06:31 AM
Rakthi's Avatar
Rakthi
Here you have them, but unless you are a seasoned mechanic, I would spend the $ and get myself a service manual. You can get them on ebay at reduced prices if you don't want to make the dealer happy. This is not a simple job and you will need some special tools.
Pivot shaft nut 90-110 ft-Ibs 122-149 .1 Nm
Rear axle nut 60-65 ft-lbs 81.3-88 .1 Nm do not exceed 65 ft-lbs (88.1 Nm)
Clutch diaphragm spring retainer bolts 90-110 in-Ibs 10.2-12.4 Nm metric
Clutch hub nut 70-80 ft-Ibs 94.9-108 .5 Nm left hand threads, apply two drops of LOCTITE THREADLOCKER 262 (red) to last few threads
Compensating sprocket bolt 155-165 ft-Ibs 210.1-223.7 Nm apply two drops of LOCTITE THREADLOCKER 262 (red) to threads
Primary chain tensioner fasteners 21-24 ft-Ibs 28.5-32.5 Nm
Primary chaincase sealing fasteners 25-27 ft-lbs 33.9-36 .6 Nm Special sequence to tighten
Primary cover fasteners 108-120 in-lbs 12.2-13.6 Nm special sequence to tighten
Transmission lockplate screws 84-108 in-Ibs 9.5-12.2 Nm LOCTITE patch, use 3-5 times
Transmission sprocket nut 100 ft-Ibs 135.6 Nm right hand threads , initial torque only, apply several drops of LOCTITE THREADLOCKER 271 (red) to last few threads
Old Sep 10, 2010 | 04:04 PM
20Sporty06's Avatar
20Sporty06
thanks man... have the tools. just didnt knolw specs. and didnt wanna give the STEALER any more money that i have to.. belt cost me 216
Old Sep 15, 2010 | 07:30 PM
StewPidaso's Avatar
StewPidaso
Stage III
Would it be safe to assume the same specs aplly to all softails 2000 and later?
Old Sep 15, 2010 | 07:56 PM
Rakthi's Avatar
Rakthi
Not really ... just checked and the compensating sprocket bolt for the 2009 is different, and within 2009 the rockers have a different torque on that bolt than the other softails ...
The rear axle nut on the 2009s is also not the same.
FXD2003Rider
Feb 11, 2025 07:57 PM
rick27
Jun 14, 2024 07:40 AM
Shag67
14
Nov 26, 2019 02:31 PM
Todd300
May 3, 2009 10:37 AM
Littleshack
Exhaust System Topics
Mar 15, 2007 04:53 PM
