Dang it you are making us all jealous and everyone knows what is next... Engine builds across garages in the US. Cant wait to see the rest of the pics so i know what I will be getting into.
The rest of the pics are just reassembly. Very simple but a bit time consuming. I'll get them up tonight when I get back from putting some miles on it. Total cost was not too bad. The 95" kit retails for $739 but can be had for less online. And I discovered teh that the base o rings I thought were missing from the kit were actually there.
The wrist pin clip installers would have helped, but you can get by with a needle nose pliers. Also the pushrod clip installed would have made this part a bit easeir but I used a screwdriver and brute force.
Torque wrenches are a must. Manual is a must with the torque values. 12 point socket for the headbolts. I already forgot the size.
Cool thanks. Will be adding to my winter mods. SE 95" kit, Fueling cam plate and oil pump, and Andrews 26 or 31 cams. and i hope to be calling ya about an air ride kit.
Any special tools for this other than the ball end allen?
you are going to love it man!!! 2 things i recomend, make sure you upgrade to the 25* injectors (i wish i had) and compression releases are nice as well!
When I get to the heads they are planned. Who has a used set of TC88 heads they want to sell cheap? If you have them I'll have them sent them directly to Big Boyz for port and polish. Pm with pricing if you got 'em!
