Mini apes on night train
Old Oct 11, 2010 | 08:49 PM
SGTGunner's Avatar
SGTGunner
Default Mini apes on night train
After asking around and sitting on some bikes I've decided to put some mini apes on my 08 Night Train. Originaly I wanted some Crossbones bars but found a set of 12"ers that after a lot of measuring and sitting on my bike I think will be perfect.
SOoooooooooooooo, I'm hoping to hear from anybody who has done similar and if any of the stock cables, wires, or lines worked......or if I need to get all new and if so how long.
Old Oct 11, 2010 | 10:04 PM
Photobiker's Avatar
Photobiker
Did my 07 and you will need a new clutch cable for sure, and brake line but the other electrical ones will work there is a bunch folded up under the tank
Old Oct 12, 2010 | 09:16 AM
Schaub85's Avatar
Schaub85
I'm rockin 14's and I had to add 12" to the stock length of all cables.
I'm 99% sure you cant use the stock cables.
Old Oct 12, 2010 | 10:28 AM
klf33's Avatar
klf33
It all depends on the 'risers'. I went from 9" risers+ drag bars (previous owner) to 12" Zee bars that has a bit of a pull back and down and 1" RSD riser, and was able to keep my stock (FXST) front break cables.
I went with new throttle/Clutch.
Not all 12" are the same, not all risers are the same.
Also keep in mind, that it is very fashionable and hip to have the bars roll forward a bit, (yes I know fashion comes and goes, but this one is staying with me), some bar makers, have the bars with a slight bend half way, but if you roll the bars forward, you may find a 10" bars is better as they get taller and further from you a bit.
Hope this helps.. but apes .. are just SO friggin much fun
Old Oct 12, 2010 | 11:45 AM
magna's Avatar
magna
Yep youve got to get all new cables,ive got mini apes on my train.
Old Oct 12, 2010 | 01:22 PM
Ash16's Avatar
Ash16
Put these 8" bars with 1" risers on mine with stock cables and it was a stretch. I had to "modify" my clutch cable and brake line. Don't want to change my cables cuz I like to change out between these and the stock drag bars with 6 and 8" risers.
Old Oct 12, 2010 | 04:14 PM
booger 18's Avatar
booger 18
I'm putting apes on mine this winter...( ol lady pissed, she likes the drag bars ) I'm going with 10" or 12".....seen some nice pics to help with the choice.....
Old Oct 12, 2010 | 06:29 PM
SGTGunner's Avatar
SGTGunner
Thanks yall. The 12"ers and 1.5" risers are on order. I dont care much for fasion or trends, I just want to be comfortable enough to ride my bike more than a hour and a half, wich I'm not able to do now with the drags due to a messed up back.
I was pretty sure the cables and brake line wouldnt reach, just wasnt sure by how far. I wanted to go ahead and order some so I wouldnt be bikeless....but think I'll wait till they get here so I can do it right. But now I know I can start pricing cables and a line 10" or so longer!
Thanks again
Old Oct 12, 2010 | 06:35 PM
DyNaBoB's Avatar
DyNaBoB
plus 6 on everything...look up the stock size then add 6 some cables might come in 7 too but dont go under 6 inch
Old Oct 12, 2010 | 09:43 PM
story808's Avatar
story808
12.5's... This should be close as it's been awhile...
Throttle & Idle --- 37"
Clutch --- 68"
Brake line --- 46"
Or as close as you can get...
What bars are you going to be running?
And you'll need wire extensions I buy the color coded ones it just makes it easier.
How about the poly bushing for the riser bolts? You'll wanna order those also... Heat shrink?
I try to think of every thing I need before I start and so should you... I hate starting something
and not being able to finish because of something really small that I over looked... But thats just
me.
One more thing if going from the 6" risers to the 1.5" riser... I'm pretty sure you are gonna need
new riser bolts... I did... You can get grade 8 bolt from the hardware store.
Oh yeah the brake line ends they come in different degreees of angles and I can't remember what I'm running.
Keep in mind that different bars may not measure the same some are more narrow some have more pull and so on... Good luck with the apes I know you'll luv 'em.
