Jump starting
Old Nov 5, 2010 | 12:52 AM
flh80's Avatar
flh80
Only if you hook 'em backwards does it mess up!
Old Nov 5, 2010 | 05:16 AM
Savgator's Avatar
Savgator
Well, I must have gotten lucky. I replaced the cables with aircraft grade cables, and replaced the battery with an Interstate brand and.......it turned right over! Wooohooo! It's about time that damn $10 bell worked!!!
Old Nov 5, 2010 | 06:47 AM
Doug S's Avatar
Doug S
I have a carb'd bike so if there was someone around to jump the battery then they could just give me a push.
Can you push start a FI bike? Just asking incase I run into the situation sometime..
D
Old Nov 5, 2010 | 08:17 AM
jimmers1817's Avatar
jimmers1817
I tried once, didn't work.
Old Nov 5, 2010 | 04:06 PM
1hellbent's Avatar
1hellbent
The state of the discharged battery will determine the risk of any damage occurring when the donor vehicle’s engine is running. Also, the larger the donor vehicle’s charging system, the higher the risk.
If the discharged battery is just slightly low enough to where it won't crank the engine over, the back EMF voltage of the battery will limit that massive current surge from the donors charging system. Still no guarantee though, it can still happen.
If the battery is deeply discharged to where you don't even get lights, you’re almost guaranteeing that there will be a surge of sort. These surges are also associated with high voltage spikes. And even though they are milliseconds, they can still cause damage to a charging system. It's not guaranteed that it will do damage, but much more likely.
With a really good set of cables, it's not necessary to have the donor vehicle running, especially when the donor vehicle is a car. Not having the motor running is the safest way by far. Even if the donor vehicle is another motorcycle, as long as it's a battery of equal size or larger and it's fully charged, the engine doesn't have to be running. Just don’t keep cranking on it when there are other problems keeping it from starting, otherwise you are going to end up with 2 dead batteries..... Doh!
Old Nov 5, 2010 | 07:54 PM
1st 96 ultra's Avatar
1st 96 ultra
Originally Posted by wouldie59
I was stupid and left the ignition on. Not even a click when I came out. Jumped it from a buddy's bike with cables and four sets of needle nose pliers. It worked, but it was a PIA.
Has anybody ever thought about connecting the battery charger connections between two bikes using the HD charger extension cable? It might not be an immediate start, but maybe locking the running bike at 2k for a few minutes might be enough to crank the dead bike. A fist sized coil of extension cord beats a basketball wad of jumper cables any day in a saddlebag.
made up a set like that to plug into my bat tender plug so I don't have to pull the seat off , just let it set a min , other end has clamps with the plug
orin
Jul 9, 2013 04:43 PM
Grandslam
Mar 22, 2013 05:32 PM
rufasim
Jul 6, 2012 11:45 AM
AdrianVall
Jul 3, 2009 04:21 PM
dclapp
Apr 23, 2006 05:19 PM
