I am replacing my tank emblems this evening. Putting on the '61-'62 emblem.
Looking for some tricks to the trade on emblem removal. Its on my new paint so I want to be extra careful. My plan is to attack it with the heat gun just as I did the reflectors. Is there any other best practices that can be shared?
Per request! For the record the '61-'62 emblem is class!
I will get better pics.
Before:
After:
Reason: Updates
I've done it two ways with equally good results.
1) Use a heavy piece of monofilament line (garrote strength, not trout). Run it slowly from one end of the emblem to the other. This will lift it. Wrap the ends of the line around some dowel to save your hands.
2) Preheat a little with a hairdryer, and use a credit card the same way.
No matter what you do you're left with a job to cleanup. I used goo-gone for the leftover residue but it still took a while.
I would suggest removing it as close to the paint as you can. If you can leave the foam backing on your deluxe wings it will be helpful for the next application,(in case you want to sell them or reapply them.
Normal two-sided autobody tape is not really thick enough to reapply the emblems if you've removed that thick foam tape the manufacturer uses.
