Removing throttle cable help
Old Nov 2, 2010 | 05:56 PM
Reaper13's Avatar
Reaper13
5th Gear
Default Removing throttle cable help
I am in the process of changing my 09 train over to some 14" apes. I am wondering how the throttle and idle cables come out of the controls on the handle bars. I have the control split apart but i cannot seem to see a retainer clip of any sorts inside. Not sure if I am being descriptive enough but any help would be greatly appreciated.
Old Nov 2, 2010 | 06:17 PM
coronerrpm's Avatar
coronerrpm
All you do is pull on it and it will let go. The little clip is up inside the housing a bit. There may be other ways but this is how I always did it.
Old Nov 2, 2010 | 06:18 PM
franticbilly's Avatar
franticbilly
You should just be able to pull them out. There is a little compression ring on the end of the fitting. Since they are very new, it may be rather tight.
Old Nov 2, 2010 | 06:21 PM
luvtoride's Avatar
luvtoride
http://www.youtube.com/watch?v=LEE2RZngLng Watch this video.
Old Nov 2, 2010 | 06:51 PM
Reaper13's Avatar
Reaper13
5th Gear
thanks for the input, after looking a little more i found the ring and just had to pull on it a couple times and it popped right out. Thanks again.
Old Feb 16, 2011 | 05:06 PM
po1192's Avatar
po1192
helpful.youtube video
rgjujitsu
Oct 17, 2012 03:40 PM
jbrady5979
Oct 14, 2011 11:56 AM
champ198
Nov 10, 2010 06:42 PM
GPHDXLC
Dec 30, 2008 04:10 PM
shengte
Aug 5, 2007 12:42 AM
