Skull Brake Pedal Pad - Poor Quality
Old Nov 3, 2010 | 10:59 PM
azfathog17's Avatar
azfathog17
Default Skull Brake Pedal Pad - Poor Quality
I was tightening my shifter pegs and checked the brake pad which felt loose. So I tried to tighten it but it feels stripped or something has broken off inside. It will not tighten or loosen. I expect better quality from HD even on the Asian made accessories which I believe these are. At this point I am expecting it to fall off in the future which does not give me a warm fuzzy. If this does happen I will probably replace it with the stock rubber pad. I might call the dealer to see if they can do anything since I still have the receipt and it is only about 9mos old. This plan worked with a defective temp gauge I had.
Old Nov 3, 2010 | 11:58 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Good to know. Good luck
Old Nov 4, 2010 | 02:09 AM
SMF's Avatar
SMF
That sucks bro
Old Nov 4, 2010 | 06:34 AM
brettnbama's Avatar
brettnbama
Damn, I just replied in your other post about the shifter peg. When I was changing my Road King back to stock, My skull brake pedal pad did the exact same thing. What is probably wrong with yours is the same as mine. The nut which is attached inside the brake pedal pad has broken loose. It is going to be a b!tch to get loose. A tech at HD got it off for me and rewelded the nut....
Old Nov 5, 2010 | 12:06 AM
azfathog17's Avatar
azfathog17
Thanks for the info. I was trying to recall how the screw was held in. Yes that makes sense now. I may try and take it off. It is frustrating because I do like the look. I am going to call the dealer so perhaps this quality issue can get fed back to Milwaukee. Perhaps I will get lucky and they will help me out.
jockotwin
2014-2024 Touring Models
Oct 28, 2014 08:00 PM
Jmbeebe0722
Mar 12, 2012 02:04 AM
m3apx
Jul 8, 2010 09:53 PM
Tiffy
Feb 24, 2010 01:24 PM
HarleyWood
Sep 27, 2007 07:02 PM
