5 degree rake setup ?'s
Old Nov 5, 2010 | 08:32 AM
JayTee's Avatar
JayTee
Default 5 degree rake setup ?'s
I am looking to add a 5 degree rake bolt on kit to my 2007 Deluxe.
I have a 23" wheel front and 18" rear to install.
I wanted to add a 5 degree rake kit.
My question is, can this be accomplished without any major modifications and can someone explain (in English) what trail is and what to expect?
Thanks, JT
Old Nov 5, 2010 | 11:49 AM
Ash16's Avatar
Ash16
I hear ya Jay. I would like to add 3 to 5 to mine also.
Old Nov 5, 2010 | 11:52 AM
Ash16's Avatar
Ash16
Story808 added a 3 degree rake triple tree to his and Sliver added 3 degree cups by vulcanworks to his.
Old Nov 6, 2010 | 11:49 AM
Northside's Avatar
Northside
To understand trail you need to know that your front wheel is "pulled" not pushed by your front end. To figure trail, run a straight edge along the neck of the frame to the ground, and mark the spot. Then take a straight edge vertically through the front axle to the ground and mark it. The distance that the vertical line through the axle is behind the first mark is your trail. If you have negative trail your front wheel will wobble like a grocery cart with the front wheels turned forward. Typically raked trees are used to correct trail on bikes with radically raked necks 40 degrees and over and actually help handling by reducing trail. Reducing trail on a stock bike is never a good thing. I understand some raked trees correct the trail by off setting the fork tubes to maintain correct trail.
ridedaddy
Jan 13, 2019 04:46 PM
TOE_CUTTER
Nov 14, 2017 07:24 AM
ShiftyCapone
Dec 18, 2016 07:53 PM
bagger76
Jan 9, 2011 09:21 PM
joeg2246
Apr 11, 2007 12:03 AM
