Nacelle Installed!
Old Nov 6, 2010 | 06:48 PM
creatv1's Avatar
creatv1
Another nacelle brother! Tell you what, JayDee-- that makes your bike look absolutely complete. One of the nicest rides around here, I think.
How long it take you? Did you have to grind your passing lamp bar?
Old Nov 6, 2010 | 07:14 PM
Stranger's Avatar
Stranger
Really nice looking!
Old Nov 6, 2010 | 07:23 PM
doghair's Avatar
doghair
Something about that thing with those bars that just works.
Good call.
Old Nov 6, 2010 | 07:24 PM
FREEFALL's Avatar
FREEFALL
JD,
Looks great. What bars are you running?
S/F
Freefall
Old Nov 6, 2010 | 07:51 PM
JayDee5150's Avatar
JayDee5150
Originally Posted by FREEFALL
JD,
S/F
Freefall
Thanks FREE....
Those bars are 18" Wild1's...
Thanks creatv1...yeah I'm a proud member of the Nacelle club . I didn't have to grind my passing lamp at all, but it was a very tight fit...it took me forever, and a lot of painters tape, to get the lower part of the passing lamp bar aligned without scratching the Nacelle.
It took about 4 hours total to do the install...I really went slow to make sure I minimized any scratching. I also changed the harness connector that connects to the head light, I simplified it and made it cleaner.
I do have to modify the riser cover though, my bars are too thick and the cover doesn't sit down on the nacelle like it should. I am going to have to increase the arch hight somewhere between a 16th to 8th of an inch to clear my bars so the cover will sit flush. That is going to be STRESSFUL but it needs to be done to complete the look correctly.
Old Nov 6, 2010 | 09:10 PM
OS_DELUXE's Avatar
OS_DELUXE
Look'n good JayDee!!!
Old Nov 6, 2010 | 09:15 PM
Rockyriver's Avatar
Rockyriver
Wonder if there is a way to install a Nacelle and keep my stock risers, and make it look good ? Looks great dude , I'm jealous.
Old Nov 6, 2010 | 09:31 PM
Dustmaker's Avatar
Dustmaker
Great Lookin ride JD!
I run without my riser cover on. I have a nice bar and shield riser bracket that looks good.
Jimmy
Old Nov 6, 2010 | 09:47 PM
turbois417's Avatar
turbois417
Nice,,,,,!
Old Nov 6, 2010 | 09:52 PM
JayDee5150's Avatar
JayDee5150
Thanks OS....
Question...did you have to modify your riser cover to fit over your bars?
Thanks Rocky...I'm not for sure about this, but I think if you only install the nacelle and are not interested in the riser cover it might work with your stock risers.
I'm sure one of the Deluxe guys on the forum with a nacelle should be able to chime in on that.
Jimmy
Thanks Jimmy...I will probably roll like you for a while. I've got that bar and shield riser bracket as well and I've always like it a lot...i'll ride like that until I get the nerve to sick my dremel on my riser cover.
