Nacelle Installed!
Bugs thats funny that you say that, thats what made me go with the nacelle. After I saw OSDeluxe's ride the front of my bike didn't look right any more. MOCO should make the luxe with the nacelle on it from factory. I think some of the guys on this site would do a better job at designing harleys then Willie G and his crew....haha
Removing 1/16"-1/8" shouldn't be too bad. Does the cover have a flat surface or slightly curved?
Carefully measure and tape above the cut mark using blue masking tape. Cover the entire piece to protect from scratching.
Repeat the taping above the mark with 3/4" tape and built up with several layers to create a thick fence.
If you're only removing 1/16" (and the cover is flat) I'd use a bench-top belt sander. Most are equipped with a 5" disk on the side. 150 grit on the disk/belt should be good. Finish off the inside radius (handlebar) with a series of drum sanders chucked in a drill press. A Dremel is O.K. but you're limited to a 1/2" drum bit, and is difficult to smooth the entire radius uniformly.
If the cover is heavy gauge steel or otherwise, use a bench-top band saw w/ fine-tooth blade. Sand the cut smooth as described.
Good luck.
The cover isn't perfectly flat, but might be flat enough to work on a bench. My problems is, in my poor mans garage, all I have is my trusty Dremel. I have had luck cutting chrome pieces with it before (I trimmed some fat off of my old lower chrome belt guard), but this is a lot different.
After reading your advice, I'm getting the feeling that this should be done with professional tools because for 1) It is right in front of the bike, and is going to be one of the first things people see, so if it's not cut right, it will stick out like a sore thumb...2) There needs to be two identical arches cut on each side to flow around the bars, that might be almost impossible with a Dremel.
There are a lot of machine/metal shops in my area and in this case, It may be best to spend a some money (within reason) and have a shop do it.
I felt the same way as you do...it really does change the attitude of the bike. I took a while to save up for it, as these things are, IMHO, way overpriced...but after getting over that, it is worth it.
It really fattens and fills up that front light area doesn't it...brings back that old 50's/60's FL style to our new bikes.
You can easily replicate the curvature of each side by making a simple template based from the original piece using cardboard stock (file folder or cereal box material). Simply transfer the outside dimensions onto the template material and trim the curvature of one side (X-acto knife, scissors, etc). Once you've got a clean fit, reverse the pattern for the other side.
You will be surprised how accurate something can be fabricated using the simple trial & error method with a test material.
Once satisfied with the 'clean' template, transfer that onto some self-adhesive contact paper, apply that to the cover, tape as described and shape to size - small increments.
Simple - give it a try!
