Gas drip
Old Nov 17, 2010 | 01:37 PM
MiddleAgedCrazy's Avatar
MiddleAgedCrazy
5th Gear
You guys were exactly right. Leak was at the rubber gasket under the dash. Pulled the dash (the one acorn nut you mentioned), covered the dash with soft towels and bungeed it to the tach. I tightened the hex bolts as they were a little loose and dried everything off. The bottom of the rubber gasket looks a little jacked-up but I'm going to see if the tightening of the hex bolts works before I replace it. Really appreciate all the sound advice!
Old Nov 17, 2010 | 01:51 PM
hspring03's Avatar
hspring03
Good stuff.....
For some reason HD recommends replacing those 11 or so hex bolts during a gasket change... I can't imagine why, but keep that in mind.
Old Nov 17, 2010 | 02:04 PM
MiddleAgedCrazy
5th Gear
Looks like a trip to the HD dealership for a new gasket as it's still leaking. Gonna have to siphon some gas as when I went to loosen the hex bolts to pull the gasket gas poured out...I'm preparing myself for a mouthful of unleaded! I'll ask about replacement of the hex bolts when I'm there. Thanks.
Old Nov 17, 2010 | 02:30 PM
2006FLST's Avatar
2006FLST
Do you have a stand you can put it on? If so that would level it out and maybe you won't loose any gas. Either way good deal and glad it was an easy fix.
Old Nov 17, 2010 | 03:02 PM
MiddleAgedCrazy
5th Gear
Siphoned the gas easily. Didn't even drink any. Think I need to purchase a manual. Pulled the hex bolts, started lifting the metal piece out that holds the gasket in place on the tank and found way too much stuff connected inside. Wasn't sure how to proceed so I put it back in place, adjusted the gasket and tightened the metal piece down. Afraid to put too much torque on those hex bolts. If I stripped one I'd really have a problem on my hands. Guess I could fill it with gas and check for a leak but I bet I still have one.
Old Nov 17, 2010 | 03:12 PM
hspring03's Avatar
hspring03
That is your entire Fuel Injection assembly under there....
Old Nov 17, 2010 | 03:15 PM
2006FLST's Avatar
2006FLST
18-24 inch pounds and the manual spells out a specific sequence
Old Nov 17, 2010 | 11:39 PM
klf33's Avatar
klf33
Great catch guys.
bowtie1989
Nov 28, 2012 07:14 PM
fogcity123
EVO
16
Aug 22, 2011 12:08 PM
cacasal
May 4, 2011 11:11 AM
cHiLi_11
Apr 25, 2008 09:42 AM
radloser
Aug 27, 2005 10:20 PM
