Works performance shocks vs Progressive 422's - worth the extra $$$??
Old Nov 22, 2010 | 11:11 PM
thewholehog's Avatar
thewholehog
Default Works performance shocks vs Progressive 422's - worth the extra $$$??
I want the best (non-air ride) shock available for my Softail Deluxe and looking for some feedback on whether the more expensive Works performance shocks are worth the extra $$$ over the cheaper Progressives.
I always ride solo, weigh 155 lbs and plan to keep the "factory lowered" ride height.
Basically I want the shocks that will give me the most comfortable ride.
Old Nov 23, 2010 | 04:46 AM
wallah's Avatar
wallah
Thanks for any feedback or advice regarding these two shocks for my application.
Save your money and get the 422's. Since you only ride solo and not overly heavy, the progressive will improve your ride considerably. No need to spend the extra $$$ for not much difference IMO.
Old Nov 23, 2010 | 08:56 AM
XARAN's Avatar
XARAN
I used Works Shocks on a couple my old Moto X Bikes and they were very good. Im running the Progressives 422 on my Fatboy and for a heavy street bike and Im very happy with the ride , your HD will never be a racer. Save your money and go with the Progressive. I dont think you will or could ever pish the HD to the point where you would feel a difference between the two
Old Nov 23, 2010 | 04:32 PM
thewholehog
OK, so you are saying that the "handling" between the 2 shocks is about the same on a HD.....
But what about comfort?? I am not looking for "racing" suspension, just max comfort.
Old Nov 23, 2010 | 05:33 PM
TCannon22's Avatar
TCannon22
Have you played around with the settings on the stock shocks?
Mine was very soft originally and was very comfy with me on it, but with me and the wife and the bags loaded, it bottomed out quite a bit.. After playing with the settings mine rides like a new bike
Old Nov 23, 2010 | 08:01 PM
thewholehog
Yeah, I am in the middle of playing around with the stock shocks... but damn they don't make adjust the bastards easy!! At the moment I have one stuck on zero preload that I can't budge and the other set as is from the factory.
Old Nov 23, 2010 | 11:41 PM
chordstrummer's Avatar
chordstrummer
+1 on adjusting the stock shocks before buying anything.
Yes they can be a b***h to break loose -- factory either Loktites them or hires gorillas to torque them down! Have to though, I think, because the two shocks are supposed to be adjusted about the same.
I ended up, after a lot of experimentation, at near maximum preload for the best combo of comfort and handling.
Old Nov 24, 2010 | 02:49 AM
thewholehog
Thanks.... the problem is that the manual DOESN"T tell you that when you adjust the preload by turning the shock body with the special tool, you have to also hold the centre spline/bolt fixed stationary with a 9/16th wrench.... otherwise it just turns with the shock and you are not adjusting anything... Trying to get two hands and two wrenches under the bike while you are on the floor with no space is a b***ch.
Old Nov 24, 2010 | 08:25 AM
Softy 103's Avatar
Softy 103
Dude your doing something wrong.
Old Nov 24, 2010 | 09:05 AM
XARAN's Avatar
XARAN
IMO the ride quality of the 422 vs the stockers is much improved. I have a more comfortable and better ride with the 422 than the HD shocks.
I had to play with the preload and ended up pretty firm to get the ride i liked with the bike lowered.
I set it up to only move about 1/4 to 1/2 inch of compression when i sit on it and this seems to work for me to provide a good ride when moving.
