ABS difference?
Old Nov 23, 2010 | 08:20 PM
TattooBill's Avatar
TattooBill
Default ABS difference?
From what I understand, the only diference between a 2010 and a 2011 fatboy lo is antilock brakes. does anybody think this is a huge difference?
Old Nov 23, 2010 | 08:43 PM
jimmers1817's Avatar
jimmers1817
Could make the difference between being dead or alive so yes I think its a huge difference. Should be standard equipment imo.
Old Nov 23, 2010 | 08:47 PM
kozy22's Avatar
kozy22
Not the only difference though, and that an option. They changed the hand controls a bit and I think the belt is a little wider from the rear tire
Old Nov 23, 2010 | 09:15 PM
FatBoyVeteran's Avatar
FatBoyVeteran
ABS only comes with the security package.....from what I understand.
They changed the Speedo from what I hear. Other than that, its the same. Except its a year newer.
Old Nov 23, 2010 | 10:14 PM
spelk3's Avatar
spelk3
The ECU is different. The information that was stored in the speedometer is now in the ECU.
Old Nov 23, 2010 | 10:32 PM
WarriorHD's Avatar
WarriorHD
Sure wish I had anti-lock brakes the other day. I locked 'em up pretty good in making an abrupt stop....Thank God I kept it up as I was sliding. Definitely an eye opener. I'm pretty sure ABS would prevent that from happening.
Old Nov 23, 2010 | 10:46 PM
Kronin's Avatar
Kronin
It's more than just a change in hand controls. Check the December issue of American Iron. There's a pretty detailed article on the new control interconnect (HDLAN & CAN) introduced with the 2011 Softails. It gives you a trip switch on the left control and a hazard switch on the right control. They basically replaced circuit connections with a data bus interconnect. You can use LED turn signals without an extra module with this new system. There are some additional protections built into the system, and lots more diagnostic codes. The turn signal module and hands-free security module were replaced with one module, the Body Control Module. Wire thickness is reduced, along with the number of wires. The high-current loads that used to run through the ignition and other switches are removed, replaced by a low-voltage data network between the switches and BCM.
Besides that, you can get the 2011 in Silver and Denim White which weren't available in 2010.
TattooBill's Avatar
TattooBill
That's what I was thinking... control was my concern.
Old Nov 24, 2010 | 12:04 AM
WarriorHD's Avatar
WarriorHD
Think about it this way...we've gotten by without ABS for years in both cars and cycles. Not saying they can't be a lifesaver but when it's your time to go...Nothing ABS is going to do about it.
Old Nov 24, 2010 | 05:33 AM
FatBoyVeteran
I've heard a few guys don't like the ABS cause in the event where you need to stop quickly and slam the brakes, the ABS kicks in and actually increases stopping distance by pulsating the brakes.
Just take your bike to a parking lot and try it out. It takes a lot of force to lock em up as is.
