You shouldn't be. I'll be using 1 1/4" dimpled bars. But I'm getting them raw, modifying, then sending them out to powder. If you plan on welding in the throttle, I don't think it matters.
The Steam line uses a vice angled piece inside the bar to lock it into the bars. Well that piece is right where the switch wiring needs to be run through. So I deleted that piece and square cut the end of the throttle body piece and used three set screws to hold it into the bars. Been working for about a year without any problems.
I dunno if anyone will see this but that brake line. How is it holding up. Any leaks or breaks. I would like to do this but am i lil concerned how it will hold up.
