27 Tooth Sproket
Old Nov 26, 2010 | 02:05 PM
ajay450's Avatar
ajay450
Default 27 Tooth Sproket
Has anyone had any experience with a change from a 25 tooth to a 27 tooth sproket as described here on 00-06 softails? I have a Fatboy 2004
http://www.hotbikeweb.com/tech/1011_...ket/index.html
I've done this on metric bikes I've owned in the past and it works fairly well and, of course, does reduce rpm's. Low end seemed hardly affected at all.
Old Nov 26, 2010 | 03:34 PM
Mikey 1450's Avatar
Mikey 1450
I'm glad to see this, been hoping for a good while someone would offer it. With the 6 spd trannys out, I figured I would not see it. Your speedo would be a little off.
Old Nov 26, 2010 | 05:52 PM
deucegray's Avatar
deucegray
Baker does offer this set up with the DD6. Call Baker I am sure they sell the 27 tooth gear.
Old Nov 26, 2010 | 07:33 PM
byersmtrco's Avatar
byersmtrco
I think this is how the Baker DD6 does the over drive, with the primary
sprocket. Since the overall transmission to rr/wheel speed doesn't change
it would not affect the speedometer.
It does sound like the easiest way to slow down the cruising rpm.
Better gear ratio for the starter too . . . Hmmmm . . .
Nordal
Oct 2, 2013 02:19 PM
AlCherry
Dec 10, 2012 06:16 PM
HDF Tech
Jun 19, 2011 05:50 PM
buckmc
Jun 4, 2008 11:34 AM
stl_shovel
Shovelhead
Sep 23, 2006 12:21 PM
