Which apes should I get?
Old Dec 9, 2010 | 10:13 AM
jdmcquerry's Avatar
jdmcquerry
Question Which apes should I get?
So I did the broomstick trick, by having the wife hold a tape measure up and away from me. Three times in a row I held the bar up to 14¼ inches.
So I'm thinking 12 inch bars with 2 inch risers will do the trick, or should I get 14s with 1 inch risers. I prefer the low risers because I just think they look better. My concern is that I will be too high with 16s.
Thoughts and opinions appreciated.
~Mack
Old Dec 9, 2010 | 10:17 AM
Kowan's Avatar
Kowan
I think the 14s would look better with the 1" risers.
Old Dec 9, 2010 | 10:29 AM
brettnbama's Avatar
brettnbama
agreed....
Old Dec 9, 2010 | 10:57 AM
Kowan's Avatar
Kowan
I went with these 1 1/2" Carlini "Boob Risers",
I'm having to shorten the riser mounting bolts that came with this Arlen Ness flush mounted bushing kit. They bottom out against the risers.
Something to think about with short risers.
Old Dec 9, 2010 | 11:12 AM
Weevil's Avatar
Weevil
This.
You can always add a taller riser if you're not satisfied with the height. Either the 1.25 or 1.5 inch diameter ones. Most bar manufacturers make a stepped down bar in the riser area if you want to use the stock risers, at least in the 1.25 inch bars anyway.
Old Dec 9, 2010 | 11:43 AM
klf33's Avatar
klf33
Also note most bars have pullback and some have pull-down, mine are like 2" down from the top of 12".
Old Dec 9, 2010 | 11:53 AM
busij44's Avatar
busij44
I did alot of research on this same question. I finally pulled the trigger on a set of 14" Carlini Gangsters. They are pricey, but worth every penny once I got mounted them on the bike. I really like the bend on them. I bought a set of blems, saved some coin and I can find anything wrong with them?? Must be a very slight blem. these on on my 07' FXSTC.
Old Dec 9, 2010 | 12:11 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
You should get some 10"ers with 4" risers.... hahahaha HUMOR!
Old Dec 9, 2010 | 12:40 PM
tas_todd's Avatar
tas_todd
Yea, what he said. If 14 is comfy for you, I'd get the 16 cuz they'll have a little drop once they get to the grip area.
Old Dec 9, 2010 | 12:44 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Mack, I have a brand new set of Burly 14" apes here in my personal collection for sale for $120 shipped. As far as height, I can't help you as we are all different. I run 16" Carlini's and am not tall, but that is jsut me.
Drew
