up the creek.
Old Dec 31, 2010 | 08:49 PM
BlockHead57's Avatar
BlockHead57
Stage IV
Default up the creek.
I am new, so hi all!
Need advice. Am restoring my first Softail (91) and found the transmission case is cracked. I found a tranny for sale, but the year is unknown. It looks almost identical to mine, the seller says that its for a softail, but I see a little opening on the sellers case about where the serial number is on my case.
careful study of the pictures indicates that all the bolt holes, openings, and shift controls are in the same place other than that little opening mentioned above. Its on the upper left side of the case above the clutch cable cover but below the top cover. Its on the top of the case where it angles down to the back tire. 10-11 oclock position. I have seen web pages that show a little cover here with a single bolt securing it.
Has anyone experience swapping trannies that can help me out???
I am a vet with Sportsters, and TC88+, but am not too clever with softails.
Advice welcome.
Old Dec 31, 2010 | 09:05 PM
ramhunter9's Avatar
ramhunter9
Bump for ya , also welcome to the forum
Old Dec 31, 2010 | 09:14 PM
BlockHead57
Stage IV
Thanks for the boost ramhuner9. probably bad night for asking, but i cracked the case just today.
What kind of dumb@ss cracks his own tranny??? one who was tired and going too far, too fast with a press while extracting a bearing. I am too bummed out to enjoy new year at this point.
Happy new year to all however!
Bluehighways's Avatar
Bluehighways
Pictures? Need Pictures!
Old Dec 31, 2010 | 09:21 PM
BlockHead57
Stage IV
https://www.hdforums.com/forum/membe...990-photo.html
In the very center of the picture is my serial number on the tranny. The box I am looking at has a little cover here. What is that cover for?
I cannot get a picture of a case with a little cover where my serial number is.
Old Dec 31, 2010 | 10:03 PM
BlockHead57
Stage IV
Default easier question
Maybe this is the real question...
are all 1990-99 softail 5 speed trannies interchangable?
Old Dec 31, 2010 | 10:45 PM
Tom84FXST's Avatar
Tom84FXST
From your description it sounds like you are describing the speed sensor hole...96 up Softails have electric speedos and the sensor goes there...if you use a mechanical speedo you can plug that hole.
Old Dec 31, 2010 | 10:47 PM
alaskajeff's Avatar
alaskajeff
Don't let it get you down man!! We have ALL done something that has resulted in BAD things. It will work out in the end. Also, when you get a chance, stop by the EVO classic section since you now have a 91, we EVO guys and gals have to stick together........Enjoy your new year!
Old Jan 1, 2011 | 10:58 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Check the starter opening to. It may be larger diameter than the early one.
mdbhunt4
Mar 30, 2009 05:40 PM
07FXSTC
Sep 8, 2008 11:08 PM
07FXSTC
Sep 8, 2008 08:23 PM
Mking
EVO
Mar 10, 2008 09:15 PM
bensonjv
Mar 10, 2007 03:32 PM
