Grease question
Old Jan 1, 2011 | 07:28 PM
ambrose's Avatar
ambrose
Default Grease question
Can you grease the pivot bolt on a Fxstc because when I bounce up and down on the seat something is squeeking and I think it is that long bolt that goes straight throuth?
Old Jan 1, 2011 | 07:43 PM
Jackie Paper's Avatar
Jackie Paper
Default No
Not with out taking it apart. It's probably the rubber pads under the seat. Pull the seat and wipe them off and put a touch of silicon rubber spray on them. If it stops you will know what it is. It will probably come back shortly however. My seat is not stock but I fitted the bushing so they all touched equally. Two of them needed shimmed by 1/4" Also could be the belt drive on the front pulley tighten up slightly. Get someone else to bounce while you listen . Sometime it take a stethoscope to pin point it.
Old Jan 2, 2011 | 09:07 AM
shineybike's Avatar
shineybike
Shock bushings?
Bogie_71
Aug 10, 2015 10:02 PM
Brad11
May 19, 2011 04:04 PM
USMCNewdog
Apr 18, 2011 07:03 PM
3/4 life crisis
Jun 20, 2008 06:53 AM
floydpink
Sep 28, 2007 04:23 PM
