Aviation fuel ?
Old Jan 13, 2011 | 03:24 PM
  #31
DamnYankee's Avatar
DamnYankee
A lot of incorrect information here. ( I am NOT an expert)
You can legally buy AVGAS (any average Joe can) I buy it at a local airport at the self-service pump. This is 100LL as stated here, which is 100 octane with a low amount of lead.
Unless you have a high compression engine, no real benefit. I run every now and again in both my 87' FXST and 09' FLHT, only cause I love the smell, and it is cheaper than most racing fuels. Only other possible benifit is is people may smell the exhaust, assume you have a race motor, and be scared to race
Old Jan 13, 2011 | 03:38 PM
  #32
jeffreydsilver's Avatar
jeffreydsilver
Default Waste of money
Avgas, your probably talking about "blue" gas, is a 100LL (octane) fuel designed for low compression/high altitude engines. While it won't hurt the bikes' engine it would definately put a dent in your wallet. Typically, aviation fuel is much more expensive than regular pump gas. MUCH MORE!
That would partially explain the meager amount of pilots wanting to get STC's (supplemental type certificates) for their planes so that they could run the cheaper pump gas. The other explanation being that when the engine quits you can't pull off the side of the road in a plane!
Old Jan 13, 2011 | 07:22 PM
  #33
Misbehaven's Avatar
Misbehaven
I used to burn a 50/50 mix of the old blue 110LL AV fuel in my cars and bikes. Never hurt them. I got the AV for free every day as I worked at Mercury Air Center in Sanata Barbara, CA and each morning we had to drain a few gallons out of the tanker truck sumps to remover settled water or particulate matter. It was considered Hazmat but we ran it thru a filter and put it in our tanks. Free Gas.... Also saved on having to pay to have hazmat removal.
Old Jan 13, 2011 | 07:29 PM
  #34
Budmiester's Avatar
Budmiester
"You can legally buy AVGAS (any average Joe can) I buy it at a local airport at the self-service pump."
You might not want that info out. We've fired people for selling to the public (Non aviation use)
Old Jan 13, 2011 | 07:42 PM
  #35
DamnYankee's Avatar
DamnYankee
Point taken. I have to assume, and only an assumption on my part, but there are different rules for for different areas. In most areas of Florida, AVGAS is available to the public for non avaition use for airboaters who run avaiton engines.
Old Jan 13, 2011 | 07:48 PM
  #36
Budmiester's Avatar
Budmiester
It's all tax based, Non hiway use is o.k., certain non-exempt orginizations. We have a couple of drag strips in our area, the Feds do watch to see if FBO's are selling to those they shouldn't. Absolutely no sense of humor.
  #37
SeeMeDo's Avatar
SeeMeDo
only if it's set up for it otherwise you might try H2O
Old Jan 13, 2011 | 08:40 PM
  #38
DamnYankee's Avatar
DamnYankee
I had not given the "tax" thing consideration,.............makes perfect sense. You are not allowed to drive to the pump and fill up here in Florida, at least where I buy AVGAS. I can pull the boat on the tralier up to the pump, and fill containers as well. I guess that way it can be assumed it is not for highway use. No real difference than purchasing race fuel for "off road use only".
There is one airport here that encourages sales to airboaters, in fact pump fuel for you.
My purpose of posting was primarily for showing it does not harm my Harleys.
Old Jan 13, 2011 | 10:01 PM
  #39
marines267's Avatar
marines267
Originally Posted by Harley03joe
Can I Use Aviation fuel In My 03 Heritage ?
I Have A Small Airport Close To Me
Thanks
Harley03joe
Read your owners manual
Old Jan 13, 2011 | 11:22 PM
  #40
Harley03joe's Avatar
Harley03joe
Post
I Did It Said 91 Octane
har1690
2014-2024 Touring Models
15
Jul 9, 2017 03:54 PM
STA-BILŽ
Dec 12, 2014 09:42 PM
oldblueroadking
Feb 14, 2012 08:25 PM
Mike Horrell
Aug 8, 2009 06:15 PM
Bobkizzmo
Jan 23, 2008 10:46 PM
