Rocker Fork Trees
Old Jan 22, 2011 | 10:26 PM
Rocker_Dan's Avatar
Rocker_Dan
For what its worth it really made no noticeable difference when I put my 21" on, no speed wobbles at all, slow manouvering was a little different but nothing that didnt just seem to go away after a few rides..
Old Jan 23, 2011 | 08:54 AM
C. Rocker's Avatar
C. Rocker
Thank you Rocker Dan. That's what I wanted to hear, the actual experiences. I just didn't want to foul up in the face of literature that says keep your trail between 4" - 6".
The look of your bike is awesome! points the way to where I want to go.
Old Jan 23, 2011 | 11:16 AM
lazyboy09's Avatar
lazyboy09
Originally Posted by C. Rocker
I talked with an independent Harley mechanic today who owns his own shop. He is suggesting that I bring the bike to have the bearing tightness checked. He said that if the bike's front end is raised off the ground and the steering is aligned straight, and then if the steering is nudged off center, the wheel should slowly fall to one side. It should not immediately flop to the side.
On the Rocker, he said the addition of the 21" wheel should not make any significant diffference in straight line stability at very low speeds, versus stock.
So that you can follow my csalculations, I am using the Advanced Trail Calculator at RB Racing http://www.rbracing-rsr.com/rakeandtrail.html. I am using 36.5 for rake, 2.4 for offset, 32 for fork length, and 1 for tree rake.
Ah, that's where the difference is. I have the rake at 36, offset at 3", fork length at 32" and tree rake at 0. I don't have an angle finder so I'm going with what I have read in multiple spec listings, but I do know the offset is 3 which can make a difference in how the calculations go. Some of us have been looking into springer front ends and have done a bit of calculating and I'm sure some guys know the front geometry like the back of their hand. LOL. There are a lot of guys running 21" fronts with no issue so I wouldn't worry about it and a 23 would look pretty damn tough!Name:  SpearfishCanyon.jpg
Old Jan 23, 2011 | 10:49 PM
C. Rocker's Avatar
C. Rocker
COOL !! Thank you!
masar
Jul 31, 2014 01:22 PM
bygcland
Apr 29, 2010 09:07 AM
user 87208922
Feb 4, 2010 11:05 PM
MCSarge
Jan 15, 2010 10:22 PM
Wallaby
Feb 26, 2009 09:18 PM
