Stage II Big Sucker....
Old Jan 22, 2011 | 01:14 PM
lomogda's Avatar
lomogda
Question Stage II Big Sucker....
I know this my be a rookie question but I need some help, I just put on an Arlen Ness Stage II big sucker and now when I take off she stutters alittle bit, like its not getting enough fuel?? I shouldnt have to re jet the card just for a new air filter should I??
Old Jan 22, 2011 | 04:59 PM
olongapo1's Avatar
olongapo1
Yes!!! The purpose of the stage 2 is to allow more air into the combustion chamber. If you don't adjust the fuel to match the airflow your fuel-air mixture will be lean. Try calling Arlen Ness for Jet size recommendations.
Old Jan 22, 2011 | 08:10 PM
bwana1's Avatar
bwana1
unless you have done serious head work, a stage 1 air cleaner will provide more air than your bike can use.
Bwana
Old Jan 23, 2011 | 07:17 AM
ejvette's Avatar
ejvette
This is why I love my FI
Old Jan 23, 2011 | 07:35 AM
hdgzr's Avatar
hdgzr
If you went from a stock application to a high flow version, like the Big Sucker, yes a rejet would be necessary.
Old Jan 23, 2011 | 08:33 AM
DRL1950's Avatar
DRL1950
So then are you saying no adjustments necessary if running Fuel Injected? Was thinking of changing the air intake on my 10 Deluxe
Old Jan 23, 2011 | 08:59 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
If running fuel injected a tuner with the proper map or a dyno tune would greatly help the engine achieve proper afr.
Drew
Old Jan 23, 2011 | 09:11 AM
DRL1950's Avatar
DRL1950
Was considering putting on a Scremin Eagle Heavy Breather kit, more for looks than anything else.
flhchaz
EVO
14
Jul 14, 2015 07:49 PM
Skeeter666
Jul 9, 2015 11:11 PM
bcane98
Sep 26, 2011 01:14 PM
MovedtoSyracuse
Aug 28, 2007 08:14 AM
docpage
Exhaust System Topics
Aug 22, 2006 09:21 AM
