Pro One front end opinion
Old Oct 8, 2006 | 02:02 AM
Soul_Cal's Avatar
Soul_Cal
Default RE: Pro One front end opinion
I've got Pro One 5 Degrees w/ Built-In Signals <Click 4 Pics>...... They look great but the front-end will wobble at high speeds (>75 MPH). Therefore, I would not recommend it. I may go back to stock powdercoated triple trees. Anyone have any for sale?
Tx_Outlaw, does your bike have the wobbles with 3 Degree Pro One triple trees?
Old Oct 8, 2006 | 02:35 AM
MAX EVO's Avatar
MAX EVO
Tx Outlaw what is your height? I thought the 501's were really comfortable for a 5" 10 guy with a 32 inseam like myself.Are you thinking about 10 inch or 12 inch apes? You feel they would be more comfortable?What are your or anybody thoughts on the H-D inverted front end kit ride wise? Better then stock or as good as or is it just for looks? thx
Old Oct 8, 2006 | 02:49 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
ORIGINAL: NightTrain245
Have you tried using a fork brace on it? Most of the "wobbles" on bikes I have ridden were caused by "loose" lower sliders. Its mostly caused when the lowers develope a little bit of slop from wear. A fork brace can reduce the effects by limiting the sliders capacity to move in any direction other than up and down. If they are installed on a new bike or fork set they can significantly extend the life of the sliders by eliminating the sidewise ans twisting torque loads that can eventually lead to the wobbles.
Old Oct 8, 2006 | 04:23 AM
Soul_Cal's Avatar
Soul_Cal
ORIGINAL: Citoriplus
Thanks for the recommendation! I just may give it a shot. Anyone else have any experience with Fork Braces eliminating the wobbles after raking their bike?
Old Oct 8, 2006 | 05:57 AM
I would give it a shot, if for no other reason then if the lowers really are a little worn. Replacing the tree's may not cure the problem, and if it does. The odds are its only going to be a temporary fix. Cause the "real" problem is still there, it just won't "feel" as bad with less rake and torque loading on the tubes.
In really extreme cases even a fork brace isn't going to help any. But is its that bad, my best guess would be that the sliders are probably way overdue for a rebuild, or even replacement.
You also might want to double check to make sure you haven't tossed off a balance weight. An unbalanced tire may feel "OK" or like an uneven road surface while going straight down the road. But start an odd vibration that feels like the thing is wobbleing on you in turns.
Old Oct 8, 2006 | 09:36 AM
skips69's Avatar
skips69
I can't help you decide on your choice of parts, but speaking of Pro 1 as a whole, I have been very happy with the parts I used from them in the past. Usually their price was the best I could find on a certain component, or their component had a certain "look" or "lines" to it that I felt was more appealing to me versus other manufacturers of a certain part. Fit and quality have always been good with my past experiences. Nice Looking Trains guys!
Old Oct 8, 2006 | 10:07 AM
jimb's Avatar
jimb
Fork braces won't stop the wobble caused from incorrect trail.You want your trail to be as close to 5" as possible.Check out Perseperformance.com and it has a rake and trail calculater to show you what kind of trail you"ll have and whether or not it's safe.
Old Oct 10, 2006 | 12:00 AM
Tx_Outlaw's Avatar
Tx_Outlaw
I'm 6'1" and the 501's are nice. I'm just ready for something a little different since I'm also looking to stretch and rake the frame a bit. Hadn't really decided on an exact bar yet.
I've got no wobble at all with the 3 degree trees. I have run steady from barely rolling to 95 mph. That's fast enough for me. I didn't buy the bike for speed, but it sure is fun to do in short bursts! I just installed a 120/70x21 Metzler on a 3.5" width wheel and the bike feels even more stable now. I had to drop the front fender and don't have a fork brace with the fatter front tire. I also run the Platinum Air rear suspension and keep the back pretty low. I love this bike! I got a lot of compliments on it this weekend to back up my desires too - that's always nice to hear!
MegaHDman
Softail Pictures
18076
Jan 25, 2023 08:24 AM
agove
Apr 12, 2015 04:08 PM
Drewcifer86
Sep 7, 2012 08:38 PM
Puggs
Aug 5, 2009 05:58 AM
carrman
Aug 1, 2006 01:09 AM
