NEed help!!
Old Feb 5, 2011 | 02:47 PM
jdsmitty10's Avatar
jdsmitty10
Default NEed help!!
Trying to install my 18x5.5 rim on my deuce in the rear. Can't someone please direct me to how to get the caliper placed so the wheel clears that but still Is able to be placed on the axle. We r stumped right now. It is tight.
Old Feb 5, 2011 | 05:12 PM
Tom84FXST's Avatar
Tom84FXST
https://www.hdforums.com/forum/softa...-on-deuce.html
Old Feb 5, 2011 | 06:01 PM
jdsmitty10's Avatar
jdsmitty10
I got it on after lots of swearing and bloody knuckles. Wow that was tight. REAL TIGHT. I don't have it completed bolted up cause I think I may need to add at small spacer for pulley clearance. But at this point I can't get the caliper to seat back where it was on the swingarm. It looks like the brake pad is pushing left which is hindering the ability of everything to come over. Any suggestions? How can I pry that piston back?
Old Feb 5, 2011 | 07:27 PM
gforrest2's Avatar
gforrest2
Fought the same battle last month. What a PITA. Even when I followed the manual it was till a PITA. Did you remove the pads? That's the manual says to do. On my Deluxe, I was able to get the wheel off with the pads in place but I tried and tried and tried but could not get the wheel back in until I removed the pads. Just that little bit gave me enough wiggle room to get it back together. And another set of hands would have helped. Two hands to hold everything in place and another to shove the axle back in. Good luck.
Oh, and you'll need a tiny 12pt socket in order to loosen the pins that hold the brake pads in place. Can't remember the specific size, other than it's a 12 pt. socket.
bjewell
May 25, 2012 12:56 AM
TORQUEY
Nov 27, 2011 11:28 PM
JohnK-NJ
Sep 14, 2010 09:06 PM
drbillk
Apr 24, 2008 09:46 PM
Beavis
May 23, 2006 01:04 AM
