heartland 280 install started
Old Feb 13, 2011 | 10:44 PM
  #31
rockerz's Avatar
rockerz
that looks sooo good. keep pics coming.
Old Feb 13, 2011 | 10:56 PM
  #32
Kowan's Avatar
Kowan
Tire to belt clearance is so close, I'd hate to see that belt if you got a flat.
Good job on the change over so far though.
Old Feb 14, 2011 | 02:31 AM
  #33
DevilDogg's Avatar
DevilDogg
I wonder what's special about the rim they make you buy. I mean in theory I should be able to go buy an 18x10 rim, slap a 280 on there and it work (with a different fender)
Old Feb 14, 2011 | 03:23 AM
  #34
Rocker_UAE's Avatar
Rocker_UAE
Amazing but alot of $$$$$$$
Old Feb 14, 2011 | 04:43 AM
  #35
j33ptj's Avatar
j33ptj
Would be interesting to see a 240, 250, 280 next to each other and see if you really can tell the difference...
Old Feb 14, 2011 | 05:53 AM
  #36
TIPN8R's Avatar
TIPN8R
Originally Posted by pontoonman
Worked on the rocker a little more this weekend. got the new spacers in on friday so saturday I ran the fenders to the painter. When I got back I pulled the back tire off again and put in the new spacers. SWEET everything lines up and the brake caliper mount is center'd around the rotor.
I must say the clearances are mighty tight....
belt to tire clearance
belt to swingarm clearance
The last thing I wanted to do was check out the turn signals in the struts.
the problem I was having was the wires will not stay in the channel so
out came the hot glue gun and problem solved.
mounted them to see them work.
off
Now I wait for the fenders or the inner primary witchever comes first...
Looking good bud!
I saw Heartlands 280 kit out in Cinci at the V-Twin Expo last week and man did it look sick in person. Those LED's are pretty trick too.
Old Feb 14, 2011 | 08:43 AM
  #37
pontoonman's Avatar
pontoonman
DD the rim made by colorodo customs for the heartland 280 kit has a special offset. The box the wheel came in said rocker 18X10 280 hub so im guessing that hub measurement needs to be right.
Old Feb 14, 2011 | 10:56 AM
  #38
AZryder's Avatar
AZryder
That's gonna be bada$$.... lookin' great so far!
Old Feb 14, 2011 | 11:17 AM
  #39
cosmic tang's Avatar
cosmic tang
big difference.
Old Feb 14, 2011 | 12:45 PM
  #40
Lucky22's Avatar
Lucky22
Nice, newwww picssssssss
