Softail Security System light
Old Feb 18, 2011 | 05:24 PM
mswing1234's Avatar
mswing1234
Default Softail Security System light
I got the scoot out today for a ride and noticed after I turned the ignition on and the security light did it's usual "solid on for 4 seconds and then off" it came back on and stayed on throughout my ride. I moved the fob far away and the system seems to activate normally when the bike is messed with. The manual just states "if it stays on, have a dealer check it" and I can't find any info in a brief scan of my service manual. Any input is appreciated.
Old Feb 18, 2011 | 05:29 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Follow the instructions here.
https://www.hdforums.com/forum/softa...odes-dtcs.html
Drew
Old Feb 18, 2011 | 06:21 PM
mswing1234's Avatar
mswing1234
Thanks Doc. I had to read down a bit but I saw one HFSM error pertaining to the clutch switch short to ground. I had the left switch housing open recently while I changed my grips. I might have pinched a wire when I put it back together.
Old Feb 20, 2011 | 03:37 PM
mswing1234's Avatar
mswing1234
Checked the error codes and under "S" (TSM/TSSM) I had a B1154 - Clutch switch input short to ground. I discovered my clutch interlock switch was actually broken off. No doubt my fault and the cause of the error. I didn't know if it was historical or current so I cleared the error and the fault did not come back when I recycled the ignition. Now...do I replace that switch or just seal up the hole? I need another post to explore the dilema. Thanks Drew for the guidance.
BugBYter
2014-2024 Touring Models
32
Oct 22, 2015 08:13 PM
Phat09flhx
Aug 31, 2011 09:02 PM
duffy1
Sep 9, 2009 07:33 PM
nybober
Sep 15, 2007 04:38 PM
anubisss
Feb 12, 2007 06:14 PM
