tuner suggestions
Old Feb 19, 2011 | 05:40 PM
DirtNap's Avatar
DirtNap
Default tuner suggestions
I was running a TTS Master tune( one bike) on my dyna and had my 96 pulling hard and sounding great,,,,But the 2004 softy doest have o2 sensors so i cant do any vtunes runs,,,So i guessing i can only flash a canned map,,,,what would be the route to go,,,,screaming eagle so i can do a dyno or trust the map flash?
Old Feb 19, 2011 | 05:56 PM
hspring03's Avatar
hspring03
Power Commander with a dynoed custom map.
But call Jamie at Fuel Moto first. He can set you up with a map based on your current mods that will be pretty close
Old Feb 19, 2011 | 07:30 PM
DirtNap's Avatar
DirtNap
Or the maps that good ?,,or is a dyno a must,,,,,,,I sure wish there where o2 sensors so i could go back with a tts,,,,,
Old Feb 19, 2011 | 08:47 PM
KumaRide's Avatar
KumaRide
You can add 02's and change out the ECM on the 04 to an 05 or 06 ecm then use vtune. Or find a tuner that is familiar with TTS and have them dyno tune it. Or find a map - cheapest and easiest rout obviously. Sounds like you are experienced with vtune so if the canned map does not work out I would research the 02's and ecm. No need to buy another system imo.
If your bike is stage 1 and the map source is legitimate, ie TTS, and mapped for your bikes setup it should work fine.
Old Feb 19, 2011 | 09:33 PM
DirtNap's Avatar
DirtNap
Thanks Kuma,,,,I was just digging though ebay for a ECM,,,and also checked out the zipper auto tunes,,,,,I would prefer to change out the ECM,,,,so i can adjust when ever i want with out having to go through the whole commercial process,,,,of a dyno,,,
Old Feb 19, 2011 | 10:33 PM
Gray_Drifter's Avatar
Gray_Drifter
I used a TTS Mastertune on my 2004 Fatboy. The tuner removed my pipes welded in some O2 sensor bungs. He added his own wide ban sensors, put the bike on the dyno, built the custom map and then removed his wide ban O2 sensors and capped the bung holes. The bike runs awesome. It cost about $200 to get the pipes modified.
mpr3369
2014-2024 Touring Models
Mar 24, 2017 06:14 AM
SteelCityRider
Sep 28, 2016 06:38 PM
CJ CYCLE
The Dyno Room
Jun 23, 2016 12:07 PM
BlackBastard
Apr 13, 2016 06:44 PM
PistolPete83
Jun 4, 2013 03:22 PM
