detachable heritage bags
Old Feb 21, 2011 | 04:05 PM
jlasoftail's Avatar
jlasoftail
Ok, with all the talk the last few days about quick detach bags, and hours online looking at me options (I need a winter hobby) I have a plan. Without having my bike at home this winter to double check if this will work, I think I can get what I want without changing the looks, be able to take the bags off in under two mins without tools, and only spend $10. So here's my plan: take off the two top bolts in the bag, put on a soft rubber spacer, a wing-nut, and have a hole drilled in the stud for a cotter key to hold the wing-nut tight. For the lower brace, it will be something similar. So what do you think? It might not be high tech, or as user friendly as the barebacks, but I don't need a "wide load" sign as someone else posted. lol.
Old Feb 21, 2011 | 05:53 PM
mori55's Avatar
mori55
. I have mine held on with wing nuts on the top studs and on the bottom also. Instead of a cotter key just put a locknut easer on them . Never had one com e off yet. Also their stainless steel,
Old Feb 21, 2011 | 06:00 PM
lionsqrne's Avatar
lionsqrne
Should work. Sounds like it will. Actually the lower brace from cycle vision uses that setup. just a stud with a hole drilled through with a cotter key. I scrapped that myself and opted with chrome bolts to bolt the rubber bushing directly to the lower brace arm and then I just use one of those nuts with the nylon washer thingy in it to keep it from loosening. Yes I have to use a half inch wrench to take them off but no biggie. And when they come off the rubber bushing and all comes off so the only thing left is the bracket that it bolts to.
I like the wing nut idea though. Make sure and take pic's. I might copy if it gets the bags closer.
Old Feb 21, 2011 | 06:24 PM
jlasoftail's Avatar
jlasoftail
I'll take pics for sure, but it'll be a month or so. God I hate having the bike in storage for the winter...
Old Feb 22, 2011 | 12:21 AM
klaybus's Avatar
klaybus
Thee EZ Brackets are a sweet setup but not near as cheap if you can make something of your own.
Custardglide
Sep 14, 2017 03:36 PM
KEYBEAR
Apr 21, 2013 04:42 PM
RAWHIDE07
Jul 26, 2008 09:49 AM
Kentp
Oct 14, 2007 10:30 AM
HarleyWood
Jun 29, 2006 09:43 PM
