Whats the best spark plug???Does it really matter??
As far as spark plug technology goes there is probably not much difference between a regular ol' plug and a new concept plug other than the metals used now in the more expensive plugs doesn't tend to pit out as fast if at all like it does in a regular plug.
If you don't want to or can't figure out how to "tune" your plugs... just don't. If it makes you feel better about yourself to criticize those that do "tune" 'em... great!
that their internal resistance is 5K ohms vs. 20K for HD plugs. If you have a carb
motor it makes no difference but injected HD's knock sensor will be inoperative if
you use them - google "harley ion sensing" for definative operational parameters.
BTW - Denso Iridiums are about 6K ohms so no difference there. IMHO.
mechanics, makes all the MoCo plugs and quality control is all over the place.
Before posting about HD's unique 20k ohm plug, I went and physically measured
the resistance in 1) stock HD 6R12 2) NGK iridium DR7EIX 3) Denso iridium IXU22
and 4) new off the shelf HD 6R12PP double platinum @ $8 each. Results were
1) used stock 22k 2) used NGK 5k 3) used Denso 6k and NEW HD's - one was
20k and the other one 83k ohms / N*F*G - yep, brand new in the box and ya
can't return electrical. Yes, I'll go get another but will take my meter with me.
So much for MoCo's most expensive plug. BTW - HD sez this plug has antiseize
on it - not that I could tell.
You are making sense ?.. that is not fun ..
to the Ops...
Back to the plugs. Stock plugs work fine and are an important piece of the anti knock ion sensing built into the ecm. Another plug may or may not effect the system. Its your call, your bike, your pings
will not work with 5k ohm, the standard resistance for resistor spark plugs.
I've never had an issue with NGK, Autolite, Champion. Also have used NGK Iridiums.
I wonder if a properly tuned motor even needs the knock detection.
