Help with installing BCT Baffles!
Old Mar 11, 2011 | 06:20 PM
JPL's Avatar
JPL
Default Help with installing BCT Baffles!
Hi everyone I am back once again bothering with questions!
I am about to change the baffle on my Vance and Hines Big shot long but am having some problems... I cannot figure out how to remove the baffles that came with the pipe. Can anyone shed some light?!?!?!
Old Mar 14, 2011 | 03:04 PM
JPL's Avatar
JPL
Bump!
Old Mar 14, 2011 | 03:37 PM
DrWalkinboner's Avatar
DrWalkinboner
On my big radius 2-2 the bottom one slid right out but the top one wouldn't budge. I walked it over to Harley and they pulled it out in 2 seconds and surprisingly didn't charge me.
Old Mar 14, 2011 | 03:43 PM
FL DEUCE's Avatar
FL DEUCE
Did you do a search..... plenty of info.
Old Mar 14, 2011 | 03:57 PM
JPL's Avatar
JPL
Searched and the only strategy I found was to freeze my pipes.. But they are too big and wont fit in my freezer... So I was looking for other options...
Old Mar 14, 2011 | 04:17 PM
SlkTxn's Avatar
SlkTxn
It can be a bear. I saw on another thread in here somewhere where someone suggested after removing the set screw on the outside, start it from the inside. Then I hooked clothes hanger wire around the screw, attached the other end of the wire to a dent puller, (the sliding hammer type used to pull dents from sheet metal)...several good hits later....it finally came out...good luck! ps...love the baffles!
Old Mar 14, 2011 | 04:37 PM
coronerrpm's Avatar
coronerrpm
Yea that was me...
Remove screw from outside and put it threw a pc of metal/angle iron and screw to the inside of pipe/baffle. Put vice grips on angle iron and tap out with hammer. It is how I did it and took only a few whacks to get it done. Use WD-40 first and let soak.
Old Mar 14, 2011 | 04:39 PM
FL DEUCE's Avatar
FL DEUCE
From a search:
copy and paste
https://www.hdforums.com/forum/searc...archid=7930295
Old Mar 14, 2011 | 08:00 PM
Night Stalker's Avatar
Night Stalker
I have Big Shot Longs on my Heritage... and I too installed BCT's. I didn't have a lot of trouble getting them out though. I just sprayed a LOT of PB Blast in between the baffle and the pipe, and let it soak for about an hour. Went to lunch, came back... and out she came! You will love the sound of those BCT's! Good luck!
Old Mar 14, 2011 | 08:03 PM
TORQUEY's Avatar
TORQUEY
Originally Posted by FL DEUCE
You have a beautiful bike, FL Deuce!
