aftermarket detachable sissy bar?
Old Mar 14, 2011 | 07:38 PM
tinger82's Avatar
tinger82
Default aftermarket detachable sissy bar?
I've been looking for an aftermarket detachable sissy bar for my 07 nighttrain to tie bags too when I go on trips and I have not had any luck and I don't wanna pay Harley prices for something I use a couple times a year. Any ideas?
Old Mar 16, 2011 | 06:24 AM
Darkrider1's Avatar
Darkrider1
Default Backrest
Well I got mine off of Ebay but its made by HD but should tell you that it works great! I only use mine when the wife wants to ride along and I've never had any problems. I think Kuryaken makes a detachable also so you can check there. Check out JP cycles too!
Old Mar 16, 2011 | 09:57 AM
Northside's Avatar
Northside
Well back in the old days we made our own. If you have acces to an oxy acetelene torch and a welder, bendup some 1/2 inch square cold roll steel and weld on four tabs where the bolts for the fender struts go through the fender and have the thing chromed.
Old Mar 16, 2011 | 10:21 AM
RICHIEMACK's Avatar
RICHIEMACK
Default Sissybar
Just got a 07 twisted chrome fxstc feder rack for 49$ and a cross bones one piece black sissy bar..$50...on ebay detch...retails for $129 rack $279 sissybar,.....shop ebay mine... 06 nt
Old Mar 18, 2011 | 12:02 PM
Crossbones's Avatar
Crossbones
i made mine using 5/8 inch steel round bar, 6 foot long. heated the middle with a torch, bent it to the shape i wanted (simple round turn) and then drill pressed 2 holes in each bottom side to thru-bolt it to the side plates. i had to sand down the ends to fit into the side plate, but was really easy. the side plates i got off ebay for $20 and the bar was like $10 at a local steel shop. used acorn nuts on the thru-bolts which cost about $3 for it all. sanded it all down and painted it black.
Old Mar 18, 2011 | 12:34 PM
JakesDad1's Avatar
JakesDad1
Or use rebar, a Map-pro gas torch and do as above.
Old Mar 19, 2011 | 05:31 PM
tinger82's Avatar
tinger82
Thinks for ideas ill look into making my own since I have access to everything I need at work
tunafisher729
Jul 14, 2018 04:25 PM
dynarider7
May 17, 2018 01:38 PM
akhdrider
Jun 4, 2013 02:34 PM
army_eod
Jun 27, 2011 12:37 PM
skip3406
Dec 9, 2008 08:57 PM
