voltage reg. 2000 Heritage
Old Mar 16, 2011 | 04:46 PM
gemscape's Avatar
gemscape
Stage I
Default voltage reg. 2000 Heritage
At around 3000 rpm I'm putting out around 18 volts or so. My speedo stops odometer goes out I think that's to much voltage, my Road King only puts out around 14 volts. Also how do you get to the wire ath the 40 amp breaker?
Old Mar 16, 2011 | 05:15 PM
kkiley's Avatar
kkiley
If you running voltage is around 18, that's too high. My 2000 FB has a running voltage of 14.7. To access the master circuit breaker, you have to remove the inner fender plastic in front of the rear tire, 2 bolts and lift it up to remove.
dlwilson72
Jun 15, 2012 07:31 PM
flagshipjoe
Nov 24, 2011 01:09 PM
djbarker
Jul 18, 2011 11:27 AM
jonesgl13
Jun 14, 2010 03:33 PM
93 fatboy
Apr 28, 2009 05:16 PM
