puffin smoke
Old Mar 19, 2011 | 03:25 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Seafoam isn`t going to do a thing for an engine that is using oil (although from reading various bike and auto forums you would be led to believe it will cure any problem under the sun).
02 sensors? The engine being discussed is a 94 Evo.
Take the anti-dealer always go to an Indy stuff with a grain of salt...
There is no shortage of independent hacks out there....
Don`t get too wrapped up about a little smoke, no need to run to the nearest mechanic (if you don`t do your own work).
Just ride the bike and watch your oil consumption to see if there is a problem. No need to run to an Indy (or God forbid... the dealer), unless you know the engine is using oil.
Old Mar 20, 2011 | 09:11 PM
Dorkman's Avatar
Dorkman
How many miles on the engine? Even a well cared for engine can get a little loose after 80K miles, some more, some less. The above responses are possibles, except the 02 sensor.
Old Mar 21, 2011 | 01:34 PM
cpiad's Avatar
cpiad
Account Closed
No kidding!? Really!? 94 evo is not fuel injected ... oh come on!?
Some guys who will read that BS about using Seafoam may have an EFI engine ... and they do have 02 sensors ... and a whole can of that useless junk in a 5 gal dilution can do some harm .... heck .. most likely will do some harm ... next time I'll be specific ...
Now .. back to the 94 Evo ... not fuel injected? Really ... ? You sure ... you got evidence!?
Old Mar 21, 2011 | 01:51 PM
cpiad's Avatar
cpiad
Account Closed
Originally Posted by handyhoward
Now what old wife told you that? Would take some empirical data to convince me of that!
....given your "wife" comment, perhaps you meant "scientific" rather than "empirical" .. because if you are looking for "empirical data" which is based largely on observation rather than veriable cause-effect testing .. then surely you can get a wife of your own to Google "Seafoam effect on 02 sensors" and you'll get all the "empirical data" you want ...
Oh ... I asked a bunch of old wives about Seafoam effect on cats ... and to a woman they said that junk is even deadlier to them ... jeepers ... as to wether I need to waste any effort convincing you ... I'd rather take a nap.
Old Mar 21, 2011 | 01:57 PM
Sgt_Jim's Avatar
Sgt_Jim
so... in other news.. i heard there was a 94 fatboy blowing bluish-white smoke.. wonder where the dude went and if his problem went away..
ladeda..
Old Mar 21, 2011 | 02:26 PM
Bikenator's Avatar
Bikenator
From: in a trailer next to a ditch in South Florida
Originally Posted by fatboy1340
own a 94 fatboy. it's puffin smoke when it idle's. do i need to worry?
If this is a new issue...it just started after an oil change, then probably not to worry.
If it's been happening for some time, get a compression and leak down test done. Go from there. Puffing blue smoke is not good.
Old Mar 21, 2011 | 04:36 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The engine being discussed is an engine in a 1994 Fat Boy.
I thought the Fat Boy did not get fuel injection until after the Twin Cam, but I don`t know everything...
Just because you don`t agree with someone does not mean you have to answer with a rude and obnoxious post, because you just might be wrong...
Cheers
Old Mar 21, 2011 | 05:33 PM
handyhoward's Avatar
handyhoward
I call bullshit on your "opinion" that Seafoam harms o2 sensors... the data just isn't there. When used properly... insert here "read directions"... 1 oz per 1 gallon of fuel... that's 5 oz for a 5 gallon tank... so roughly 1/3 of a 16 oz can for a 5 gal tank... not a whole can... Seafoam works well when used properly.
Old Mar 21, 2011 | 05:50 PM
fdb2007's Avatar
fdb2007
never had even heard of seamfoam till I came on to this forum. I have no empirical or scientific data to support it, but have bought a couple of gallons of different additives over the years for cages and none of them made an a bit of difference in any problem I had. I got a $20K bike, if it's got a problem I am not dumping in a $8 can of anything in it hoping to fix it. Had '67 pickup that blew lots of blue smoke and consumed oil--about 2 qts to a tank of gas. Threw a case of oil in the bed, problem solved. Truck ran for a few more years after that. If I had a 94 Fatboy with an EVO and it was puffin' blue smoke, I wouldn't worry about it till I was ready to spend some big bucks freshin' up the motor. You know how they say check your oil at every fill up? You might want to do that.
gallantag
EVO
18
Oct 21, 2017 08:28 AM
Pix
May 5, 2015 06:11 PM
wayne-o
Exhaust System Topics
Jun 29, 2010 09:43 AM
cookieman
Mar 30, 2009 04:32 PM
