puffin smoke
Old Mar 17, 2011 | 06:20 PM
fatboy1340's Avatar
fatboy1340
6th Gear
Default puffin smoke
own a 94 fatboy. it's puffin smoke when it idle's. do i need to worry?
Old Mar 17, 2011 | 06:42 PM
Rakthi's Avatar
Rakthi
What color?
Blue smoke = oil
Black smoke = too rich
White smoke = condensation
Old Mar 17, 2011 | 06:54 PM
fatboy1340's Avatar
fatboy1340
6th Gear
bluish white
Old Mar 17, 2011 | 06:58 PM
jlasoftail's Avatar
jlasoftail
did it always smoke?
did you make any changes lately?
have you had to add oil?
Old Mar 17, 2011 | 07:33 PM
cpiad's Avatar
cpiad
Account Closed
Originally Posted by fatboy1340
bluish white
What does it smell like? From the color....it sounds like oil. It's probably smokin underway but due to higher volume of exhaust gases the smoke diluted. I'm sorry to suggest it might be piston ring or valve seat or stem. I woulfv
Old Mar 17, 2011 | 07:36 PM
cpiad's Avatar
cpiad
Account Closed
bluish white
What does it smell like? From the color....it sounds like oil. It's probably smokin underway but due to higher volume of exhaust gases the smoke diluted. I'm sorry to suggest it might be piston ring or valve seat or stem. I would go easy on it until you can get a good wrench-turner to look at it. Stay away from dealerships. Find a shop with good rep....and try and strike up a friendship....its not gonna be cheap..but here's an opportunity to upgun the motor.
Old Mar 17, 2011 | 08:05 PM
TheNameIs"B"'s Avatar
TheNameIs"B"
1. Did you recently change the oil?
2. Have you checked the oil level lately?
There is a difference when the engine is warm or cold, if you possibly added oil after a cold check it may just have too much. If not you have a bigger issue...
b
Old Mar 18, 2011 | 08:54 AM
handyhoward's Avatar
handyhoward
If it's puffing bluish white smoke when it's running and up to temperature then as mentioned above there's a problem... check your plugs... check your oil level... run a can of seafoam thru a tank of gas... if none of that works call AAA. Seriously... have a good independent who has never worked for a HD dealer before take a look at it.
Old Mar 19, 2011 | 08:45 AM
cpiad's Avatar
cpiad
Account Closed
Seafoam is deadly to the O2 sensors .. stay away from that stuff it will do more harm than good.
Old Mar 19, 2011 | 02:45 PM
handyhoward
Now what old wife told you that? Would take some empirical data to convince me of that!
