Oil leak
Old Mar 19, 2011 | 02:32 AM
G.H's Avatar
G.H
4th Gear
Default Oil leak
Hi i have a bad oil leak from the return hard line out of the filter housing on a 96 softy,i have replaced the rubber gromit & checked that the line was secure & in properly but it still leaks,that bad the underneath is dripping.Has any one had this problem & how can i fix it for good.
Old Mar 19, 2011 | 07:27 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Check if there is a fracture/flaw in the line itself or a flaw in the housing.
Old Mar 19, 2011 | 08:23 AM
G.H's Avatar
G.H
4th Gear
I'll take it apart in the morning as its night here in OZ & check the housing & line.The housing is aftermarket so there may be a problem with it.This is the second time in 6 months its happened so I'm not gaim to take this bike on a long ride.Will let you know if i find anything.I'm thinking i might have to use a custom housing with braided screw in lines,any suggestions.
Old Mar 19, 2011 | 09:34 AM
V-Twins & Bowties
I'd loose the hard lines. When hard lines are used alignment has to be spot on. What you might try if no defects are found is loosen the housing mount so it's not rigid to frame before tightening the lines. That will allow the housind and lines to seat and align without the added stress. Then retighten the housing.
Old Mar 19, 2011 | 07:20 PM
G.H's Avatar
G.H
4th Gear
That sounds like a very good idea,I'll try that before spending unnecessary money.Will let you know the out come.Thanks.
Old Mar 19, 2011 | 07:35 PM
SMF's Avatar
SMF
I think you might have over serviced your oil tank bro, mine did the same thing i took some oil out problem soved bro.
Old Mar 19, 2011 | 07:58 PM
G.H's Avatar
G.H
4th Gear
Nice ride BOBBEREVO88,I checked the oil level & it could be on the low side,I'm thinking V-Twins might be on to something with the alignment of the hardline.
Old Mar 20, 2011 | 12:45 AM
G.H's Avatar
G.H
4th Gear
Back again,just been up in the hill for quick squirt so far no leak.I bent the hardline a smidge so the mount wasn't pulling down on it & replaced the rubber line to the tank as i thought it was a bit tight,so far all good.Thanks for your help & stay safe.Gary Perth Western Australia.
Dragger89
EVO
13
Dec 14, 2016 06:33 AM
strangely brown
Dec 2, 2009 08:13 PM
Panamex
May 17, 2008 06:18 AM
kenn101
Oct 22, 2006 12:19 AM
DBhdrider
Oil Archive (no new posts)
Mar 5, 2006 12:31 PM
